Yes, it is. Hmm, last time I checked (few months ago) it was unavailable, thanks....
I checked the HT-forum, but unfortunately I removed all important information. I have a copy of those pages on my back-up disks, including the images. I'll look into that soon. I always use the original harness, no matter what it's status. there are always good usable parts. The only thing you need is parts and patience. In the past years I bought / got some boxes full of used Honda wire harnesses from local scrap-yards and took the tape from it (easy when you use silicon on the tape).
Are the colors of your stator wires as crisp and bright as those around your headlight bucket?
sort off, here a picture:
I wasn't happy with the degree of deterioration, so I replaced all wires from the generator by better ones. These contacts are very important, and should have a very low resistance, since you will loose a lot of power.
All colours are in there, including good bullet contacts and fuse holders. During the last 50 years Honda used the same colour for each function, only the functions grew, so more complex coloured wires in later harnesses. The basic colours remained, so plenty of them for example, winker wires are always light blue and orange, it never changed.
It didn't occur to me until you mentioned the disc brake that none of your CB450s or other Honda Twins have one. Do the steel braided lines outperform a new set of rubber lines or is it more a longevity consideration (to avoid swelling)? Did you source an NOS caliper and piston or rebuild the original?
Indeed, the only (Honda) disc brake bike in my stable. Yes, I replaced the hose, after 40 years of service it's mandatory due to safety reasons. And if you're on to it, a steel braided hose is always preferable. Yes, I did a full rebuild in the brake caliper, as well on the brake pump. Still, it's not very good. The ratio between both pistons is not optimal, actually, I need a smaller diameter piston on the brake pump, or more pistons in the brake caliper.
I'm busy with the second solution, and busy with a Brembo caliper, with two pistons instead of one. This caliper is used on many classic Italian bikes. Since these calipers can be ordered as left or right, it's possible to use them in front of the fork, just like the original.
Another reason for using this caliper is the way they're build. There is not much room from the centre of the disk to the spokes, this caliper just fits. Since I'm working at a machine builder, it's not a big issue to make a caliper holder that fits directly on the original fork. Another possibility is to go to two discs set-up of the CB500 550, but that's not what I had in mind.
