Troy
I have made sure everything is lubricated with a bit of motor oil. Would the weight of the oil make a difference?Try spraying/applying some light machine oil to the shift drum/forks and splined gears and shafts next time.
No.I have made sure everything is lubricated with a bit of motor oil. Would the weight of the oil make a difference?
I've stared at those parts for a while this morning and can't see anything out of place either. Do you have the FSM? It's in our library if you need it. I've just gone through the transmission section of the manual and don't see anything in it that looks different than yours either, but then I'm not there to see all angles of what's in front of you.Thanks for the suggestion. The pins are the same length, the bores in the drum are different depths, therefore there is only one way that the "star" can be aligned but I'm sure hoping that it is something that simple. I'm totally prepared to order an entire set of parts for a new shift mechanism from CMSNL but sure don't want to do that just to find out that's not what's wrong.
Thanks AD & Ballbearian.I've stared at those parts for a while this morning and can't see anything out of place either. Do you have the FSM? It's in our library if you need it. I've just gone through the transmission section of the manual and don't see anything in it that looks different than yours either, but then I'm not there to see all angles of what's in front of you.
Not "buttery smoothness", but it should shift fairly normally through all gears IF they're all moving in such a way that helps align the engagement dogs during each shift. When you're turning one shaft in the same direction while attempting to shift through all gears, remember that without any resistance (like the front sprocket on the countershaft with the chain on it, holding the countershaft still - or the countershaft rotating at a different speed than the mainshaft, more like what it would be if the engine was running) all the gears tend to turn at close to the same speed due to rotational friction, which could keep the engagement dogs from aligning as easily. I like to turn one of the shafts (mainshaft is easiest because of the length with the clutch removed) back and forth as I turn the shift drum. You'll "feel" the engagement dogs bumping into each other (or dogs bumping the solid parts of the gears they're supposed to engage in because the holes in the gears aren't perfectly aligned) and you just keep rotating the shaft back and forth as you nudge the shift drum toward the next gear. When you're riding and all the gears are moving at their (correct) respective speeds, all those little alignments come more quickly and naturally and it shifts as it should. If it physically shifts through all gears when you're testing it on the bench, it's likely okay.Maybe my initial question should have been more like "how should I expect the transmission to behave while on the bench?" Should it just shift from gear to gear with buttery smoothness?
Thanks for taking the time to find that for me. You are right that I have a basic comprehension but seeing it in motion is also useful. Since I haven't done any real engine work on my previous projects I thought this one was a good starting point, being about as simple as it gets. Single cylinder, 4-speed and easy enough to remove from the frame if I need to revisit something down the road. Not too intimidating.I know you understand the way it works, but an illustration of it helps to understand why all the parts have to be in motion enough to make it all work smoothly.
Is it the 13x11mm one? My first thought was for your 450, then I remembered the thread I was reading... yeah that's an oddball, I won't have one of those lying around. No 028 middle number parts on any of my bikes AFAIKI appreciate all of the insight into the transmission. I've just recently discovered that despite being meticulous (or so i thought) about sorting, storing and labeling everything as I took it apart many months ago, I am somehow missing the knock pin in the oil pump. Grrrr...It's a part worth cdn$2.25 from CMSNL with over $40 in shipping charges.
Of course it will. I literally sifted through every single part and bag of screws twice trying to find them. so frustrating. I will turn my attention to a different area of the bike for a while and see if it jump out at my. The positive in all of this is that it forces one to clean up a bit in hopes of finding it underneath of an old rag or something.Yeah, that sucks... and of course, once you pay the ridiculous prices and it arrives, the other one will suddenly jump out of its hiding place right in front of you.
Troll the floor and under-bench area with a magnet attached to something, with any luck it just rolled on its side to behind something that rarely gets moved. When I was around 7 or 8 years old, my father taught me the trick of using a flashlight parallel to the floor to better see the tiny thing(s) you dropped, and it has saved me more than a few times when everything in the overhead view just seems to run together.The positive in all of this is that it forces one to clean up a bit in hopes of finding it underneath of an old rag or something.
This is it, but I just noticed that it applied to engines up to engine number 677883 but no obvious mention of what the change was afterwardBTW what is the part number?
They switched to a completely different oil pump.This is it, but I just noticed that it applied to engines up to engine number 677883 but no obvious mention of what the change was afterward
Thanks, I'd seen that too...shipping usd$20...still expensiveFound them available on ebay for US $3.49 but not sure what the shipping would be to your location in Canada.
Knock pin found. As hoped it turned up when I was assembling a different area of the engine. Must have just landed in the wrong bag during disassembly.Of course it will. I literally sifted through every single part and bag of screws twice trying to find them. so frustrating. I will turn my attention to a different area of the bike for a while and see if it jump out at my. The positive in all of this is that it forces one to clean up a bit in hopes of finding it underneath of an old rag or something.
That's a relief, especially in your case as that's one of the more odd-sized knock pins.Knock pin found. As hoped it turned up when I was assembling a different area of the engine. Must have just landed in the wrong bag during disassembly.
Thanks, I can have something like this delivered in about a week. I'm pretty certain that it won't mount properly and it gets poor reviews so I don't see any point. I have sent a message to Matt at Sparck Moto to see if he might have something available and am just waiting to hear back from him. The original coil worked well enough for me to briefly get the bike running a year ago before I pulled everything apart. It's just the difficulty in accessing it in the future that makes me contemplate preemptively changing it.On my 1965 S90 project the coil was bad so I ordered one from E-bay which the ad says is a direct fit but while it worked is not an exact fit and required making some spacers and using different fasteners to get it to mount and ground properly. I have had no problems with it and the price was right. The S90 was my first bike restoration and i wish I had taken more pictures and documented things better.
Ignition Coil For Honda CB100 CB125S CL100 CL125S CL90 S90 SL100 SL125 XL100 | eBay
Compatible Fit Model : CB100 CB125S CL100 CL125S CL90 S90 SL100 SL125 XL100. Fit : Honda. This parts is direct fit for the models listed below and installs with your existing hardware.www.ebay.com
I would tend to agree but I can't find a spot that it would fit and serve that function. If I try to find a spot for that match the orientation in the parts diagram it would go here but I don't think that would do anything at all and probable wouldn't stay in place for long at all.I honestly think it acts as a dust seal to prevent dust and debris from getting into the end cap area. Tried to find an ebay listing with the whole assembly to look at but never saw that piece.
Did you take the bulb out of the socket and examine the socket? Sometimes the inside of the socket gets corroded a little and/or the lead contacts on the bakelite plate, which only has a small locating tab to keep it properly oriented in the socket, can cause trouble.You are correct. There isn't a good ground from the light socket to the frame but I anticipated that and ran a ground wire direct from the bulb socket.
There is a common ground wire that runs directly from the headlight to the battery and collects the ground for a few other things along the way (rectifier, signal switch, high beam indicator) I added the ground for the tail light to this with no success, despite it being a known good ground. All other lights work as they should except the tail light, however, when I unplug everything else from this very same ground wire and leave only the tail light connected it works.
So, the tail light works with this ground until I plug the headlight and signals back in and then it stops working.
As I've said, I can run the tail light directly to the battery and everything works so I have a solution but not an understanding of what's happening.
On my early S90's (1965 and 1966) I think the socket was grounded to the tail light/license plate bracket. The bracket was grounded to the fender (bare area on both the bracket and the fender. The fender grounded to the frame at 4 (if I recall correctly) attachment points. Lots of places for this ground circuit to fail. At least that's what I THINK I remember.Did you take the bulb out of the socket and examine the socket? Sometimes the inside of the socket gets corroded a little and/or the lead contacts on the bakelite plate, which only has a small locating tab to keep it properly oriented in the socket, can cause trouble.
I completely swapped out the old wires for new, soldering to the original contact points. Bulb is fine in the socket and the socket is clean. It's possible that I'm not communicating the scenario properly. The bulb and socket work. I have established a good ground. Everything works just fine as long as it isn't connected to the common ground that connects the headlight to the battery.Did you take the bulb out of the socket and examine the socket? Sometimes the inside of the socket gets corroded a little and/or the lead contacts on the bakelite plate, which only has a small locating tab to keep it properly oriented in the socket, can cause trouble.
That's all correct. Because I have a freshly painted fender and newly powder coated frame and tail light bracket I didn't even bother trying to establish a ground using these parts. I assembled a ground wire that I attached directly to the back of the socket between the socket and the bracket. It works perfectly and is routed with all the other wires.On my early S90's (1965 and 1966) I think the socket was grounded to the tail light/license plate bracket. The bracket was grounded to the fender (bare area on both the bracket and the fender. The fender grounded to the frame at 4 (if I recall correctly) attachment points. Lots of places for this ground circuit to fail. At least that's what I THINK I remember.
