supedaglup
Hello,
I am currently facing an issue with my bike where the left side is not firing while at idle. I noticed this when I touched the exhausts and noticed the left side was noticeably colder than the right, so when I pulled the left spark plug boot while running, there was no drop in RPMs, however, after reinserting the left boot and pulling the right boot, the bike died completely, as expected. I have noticed, however, that applying a bit of throttle has the left side come alive, but I hear an occasional misfire as well out of the left.
I have a brand new battery, spark plug, and condenser so we can rule those out. I have bench sync’d the carbs initially with the guitar wire trick but I don’t have a vacuum sync so I can’t do that. The idle with just the right side is sitting at approximately 1100 right now. I tried turning the idle speed screw until the left side came alive but all that did was introduce a sort of “stuck throttle” condition where it was very slow to reduce RPMs after applying throttle as well as a slow idle creep, so I put it back to where I originally bench sync’d it.
Any ideas on where to start? My first thought was to rule out a vacuum leak at the rubber intake manifold boot but if you followed my whole debacle on Reddit it turned out the ones I bought from those guys in Houston were actually ones for the 450 and won’t align properly with my stock airbox setup, so I am waiting for a replacement OEM style one to come in. I unfortunately cannot give any compression readings because the cheap kit I bought from Amazon had their threads immediately misalign and strip on their first use and are not giving me anywhere close to an accurate reading.
Thanks for your help.
