mikemill
My pipes came back from the ceramic coater today and I couldn’t be more pleased with the results. So shiny!
Last video! Your cable is in wrong. The larger nut piece that's partially a sleeve fit inside the cable perch, the other nut is a lock nut and is on the other side.
Also you're missing the brake stay lock washer tab
I used WD-40 to slip the grips on, which evaporates and gives a nice snug fit.
Awesome tip. Grips are always a pain. I like the hairspray method too! Used to do that for BMX bikes. Also works if you have an air gun.
Bike looks good so far!
I really dig the style of this bike. Are you still riding with no gauges?
Hey Mike, I found an angled speedo drive in a box. It's from a Nighthawk but might work
OK GUYS, THAT IS IT FOR PORTING EVERYTHING OVER FROM THE OLD FORUM. ANYTHING YOU READ BEYOND THIS MESSAGE IS NEW STUFF. PLEASE RESPOND AS YOU WOULD NORMALLY!
It's always a good idea to smoothen the sharp edges with a round rasp or even better with a dremel. It's easy and gives you peace of mind.
But to be honest I'm a little concerned about your drillings. The handle bar looks like it's made of aluminum and your two drillings look IMO like a potential weak spot. I would be concerned about a weak handle bar. Maybe others here should weight in because it's a safety issue!
After moving across the country (MN to NC) for my wife's work,
Hi neighbor!
