Honda55
Ok, so I think I'm nearing the finish line with my CB350 motor rebuild. I say 'think' because I've seemingly run into a problem with the cam shaft. I've got the cam shaft installed with the rockers properly positioned on both ends and I'm now trying to install the cylinder head side covers. But both side covers are a very tight - if not impossible - fit and trying to make the fit easier by turning the motor over isn't working, because the motor won't turn. It was turning up to the point that I installed the cam case and the cam sprocket. (I aligned the sprocket flat line with the LT on the alternator rotor before inserting the camshaft.)
Also, the rockers appear clean, with no pitting or great wear. Same with the cam shaft. The cam chain tensioner is off to allow more leeway with the chain.
My questions are: Why is it so hard to install the side covers? Should there be such resistance in turning the motor over at this point? Is there an ideal alignment for the cam shaft that allows the side covers to be more easily installed?
I've attached several photos and can share more if needed.
Any and all suggestions most welcome.
