VintageHondaGarage
Someone local gave me their top end to look at due to low compression. I couldn’t really find too much wrong with it, but I still gave everything a once over.
The piston and rings on the left side threw me off.
The left cylinder measures 64.25mm. The piston is stamped 0.25. Obviously it’s on its first over bore.
The thing is, the top two rings on the left piston are stamped 50, which in my head means .5mm over bore.
It doesn’t make sense. The left rings, when put into the 64.25mm bore, have a rings gap of .019”, which is well within the wear limit.
The right side position is stamped 0.25 and its top two rings are stamped 25, which makes sense to me.
I am confused.
I am confused.
