'65 CB160 "Ghost" Update
73Goblin
Lafayette, CA
Firstly, thx for the earlier comments and assistance! Much appreciated.
Secondly, an update: I was able to get old "Ghost" (my son's homage to her white paint and age) back together yesterday and, as expected, am experiencing a couple new items to address:
1. As is obvious from the pic, the handlebars are bent with the right side back 1 3/8" (~35mm) or more from the primary axis,
2. The horn doesn't work,
3. The mirror mounting points are stripped,
4. Likely need new brake shoes,
5. Seat needs reupholstered,
6. Etc...
But for today's insights/comments, I'm troubleshooting what I'm categorizing as 'carb issues'; for lack of a better categorization. (Perhaps more generically, 'fuel delivery issue'? :unsure: )
The old girl starts - on both electric and kick - without fail. She also runs exceedingly well through all gears with no stuttering nor sputtering or lack of power through any/all of the bands. I took her out for a spin yesterday and gotta say that she's an absolute blast to ride: quick, nimble, a bit edgy, and a real head turner (sounds like my college girlfriend - without all of the emotional headaches...).
Having read this you're likely wondering what the issue is, that all sounds great, right? Well, no matter what I've tried I can't get her to idle; not fast, not slow, not idling beyond 5 secs or so at all before dying.
Again, everything about fuel delivery, air, and spark appears to be better than 'simply operable'. In fact, she appears ro be pretty "dialed-in" for riding purposes. Just not idling. I'm considering pulling both carbs and tearing them down. However, I'd prefer not to do so if they're not the issue. Having spent a couple hrs puttering with the carbs, I've not yet resolved this and thought to post here to get your insights/suggestions. Fire away...
Lastly (for today's questions), I assume that its not worth the time/effort bending the bars back? Just order a new set? Thoughts?
Have you tried connecting the horn directly to the battery to see if it's the horn or the switch that's at fault? The switch might also have dirty contacts.
You might be able to repair the mirror mounts with a helicoil.
I would definitely try to straighten the bars.
For your seat cover, many have used this vendor:
While it’s almost a certainty that you’ll need to open the carb and clean the idle circuit - you may want to clean out the petcock and see if that improves the fuel delivery.
I only noted the horn issue when troubleshooting the carb. I *assume* its a simple wiring issue (break, ground, something) but haven't yet taken the time to check it out.
Yup, helicoil is the likely call. Amazon here I come!
Any suggestions on bar straightening? I haven't taken a look into that as yet.
Thx for the seat cover suggestion!
Thx sir, I figured that cleaning the idle circuit was the likely 'go forward'. I'd planned to install a couple inline fuel filters anyway. Looks like old Ghost is heading back to the surgical ward.
The bars are a tough one - they appear to be slightly twisted and finding the right clamping angle to bend against is going to be a fun 3D physics problem.
If you can stabilize the bike, say in a motorcycle trailer, and can find a suitable anchor point then I would try a racheting tie down strap on the end of the handlebar. The other alternative would be to remove the HB and disassemble the switches and perches. Clamp the good side down to a solid surface and using a length of pipe for leverage, work the bars back into shape.
"Clamp the good side down..." may be a bit difficult as I'm unsure which side is good. 😁
I can say for certain that she was dropped on her left side thereby shearing of the end of the knurled clutch lifter rod, damaging the dynamo cover, and bending the left foot peg up ~1"; a fairly significant drop. Sooo... would the left side handle bar be bent too forward? the righthand side too far back? I can't seem to find a schematic that shows the specs at that level.
Oh, and that's not to say she wasn't dropped on her right either. I just don't have a spoken history of that happening.
I will say that I do like the Lefthand positioning better so I may just run with that and try to pull the righthand side forward a bit. Heck, if I could reduce the diff to <1/2" it would be a win.
While I agree that bars are bent, part of the "bent" appearance is caused by the fork tubes being twisted in the triple tree. Look at the top handlebar clamp and you will see that it isn't straight. My red line shows it. 60 years ago I would have parked on the right side of a substantial tree or telephone pole and whammed the front part of the wheel sideways, into the tree. That usually corrected it. Today, I would probably loosen the bolts that clamp the fork tubes in the triple tree, and correct it properly. And, yes, whammed is a word: https://www.thefreedictionary.com/whammed.
Very Interesting! great insight. I wouldn't have caught that for some time. I did see that the Spedo was a bit crooked but assumed that that was due to the headlight mounts askew.
Is there a video tutorial on how to address this? I'd like to get her back to a weekend rider. Summer is calling, after all.
Firstly, a huge shout-out to EzPete for his assistance!
Thank you sir, very much appreciated.
Secondly, how the project came to be: I acquired a '65 CB160 that, for whatever the reason (my gut leads me to believe a limited crash was involved), didn't have a complete front fender. A PO had the front half of it removed to include the forward stays. (See pic)
Now, I'm not looking to restore the old girl to showroom quality (yet), but I would like her to be as original as I can get within reason. Upon reading about my need for a fender, EzPete was kind enough to supply one that he had kicking about his shop. (Thx again!)
Thumbing through old CB photographs I realized that a PO had cut off the front ~5" of the 'new/old fender' right at the forward stay. I've read that the two likely causes for this are 1) damage or 2) looks; some folks apparently didn't like the inherent homage to excessive CA fairings of the CB's cousins, instead looking for a more 'sporting' look. Either way... it was missing.
So my strategy was pretty straight forward: Mash-up the two fenders in order to create a 'complete' front fender.
The below pics tell the tale.
Lastly, I fitted the fender to my CB but will - when I go back and repaint her - remove the fender, clean it/prep it for paint, and during that process remove cut lines and some rivets getting her closer to original. I also intend to create and affix a forward fender license 'fin plate'. Admittedly, the plate won't be factory, but... Well, I just think they look cool. :cool:
I'll also likely fabricate the black rubber mudguards as their NOS pricing is outrageous. (~$50/per delivered)
Note: Being handy does not a metal worker nor a bike mechanic make; which I'm not - a metal worker/mechanic per se. If you have suggestions/insights/comments, by all means lmk.
More updates as the project progresses.
Nice! Glad to get that fender off my shelf and back into the wild where it belongs. It came off a CB>”CL” conversion and I think they trimmed it to match the CL style.
Carbs are officially cleaned, limited parts swapped, all jet passages were checked and made clear, and then the carbs were reassembled and reinstalled. The carbs...? Honestly? They were in pretty darn clean condition prior to the work. Surprisingly so, actually. (The pic below is PRIOR to cleaning.)
After the rebuild I took Ghost out for a ~15 min ride. Nearly flawless.
Tomorrow I'll spend some quality tuning time, however... After taking her for a spin I'm undoubtedly looking forward to early Summer mornings and open backroads through the vineyards. Mists rising in the early morning light and the promise of a solid Cabernet at lunch. I'm all in.
For those of you who own CB160s: Is it my imagination or do these little beasts have some serious low-end torque and speed through ~40 mph? Surprisingly so for 60yr old 160cc engine.
When I got back to my shop this afternoon a buddy of mine commented that I was laughing when I got underway. Oddly enough, I don't recall laughing. Must have been that good of a ride?
Man. Those carbs were in remarkably good condition. Original Keihin brass and all.
To give you an idea of how good those were - here’s what mine were when opened.
The 160 does pack some pop for such a small displacement bike - gearing also makes a ton of difference.
Laughs and smiles is what it’s all about!! Enjoy the ride!!!😁
Yowza! That looks much more like a scene from Breaking Bad than a carb rebuild. :geek:
Of "Hills and Valleys" is today's theme.
After so much forward progress a mere 2 days ago, today saw a new issue arise whereby Ghost starts and then revs uncontrollably. A bit shocking at first, then I remembered the old tried and true WD40 air leak trick and... nothing found. I disassembled and reassembled both carbs - meticulously with a cmsnl blowup diagram - and found that both are missing aN O-ring on the air intake screw (part 16 in the diag below).
Could that be the culprit? The O-rings supplied with the rebuild kit are incorrectly sized.
Also, the cables need replacing as there's no real throttle 'snapback'.
Perhaps a bit of both?
More investigation happening this weekend...
For the 'rev uncontrollably" thing I would first check your throttle cable especially at the splitter where the one of the cable ends commonly frees itself and then hangs up going back in...especially if this condition just happened after running well before
Doubtful the missing o-ring would cause the effect you describe but others here may have another view
The lack of "snap back" is the cause - not an o-ring.
1. Slides hanging in the carb. Sometimes due to getting flipped side to side when you have both disassembled.
2. Throttle cable popped out at the splitter
3. Throttle cable binding and needs lube or replacement
4. Loose tension adjuster in the throttle tube/starter button housing has shifted and is binding against the throttle tube itself
5. That left grip is too tight to said housing and is rubbing against the housing
6. Forgot to put the springs back in the carb tops
An update...
Yesterday I received the new HONDA throttle control cable. Today I installed it and, while doing so, inspected and reverified the slides, springs, slide install direction and overall carb setup. According to the diagrams, everything is installed properly. However, this hasn't overcome the reving nor the throttle handle 'snapback' issue.
Question about the Throttle: Is there a spring mechanism inside the throttle handle casing? I ask as I don't find one therein when taking it apart and I also don't see one in the literature or diagrams. Given this I *assume* the snapback is directly associated with the carb slide spring compression? If that's the case, is there a possible binding issue that I'm missing/overlooking? I ask as I assumed (incorrectly so) that the new cable would rule all of that out.
As for my cold start process, it's as follows:
1. Change the Fuel petcock into the 'On' position
2. Cycle the engine a couple times using the Kick Start
3. Set the Choke to the 'Close' (up) position
4. Turn the key to the 'On' position (green dash light illuminates)
5. Press the Electric Start
Invariably, the result of this process is for the engine to turn over on the first attempt, start, and then immediately red-line rev.
For consideration: ONLY when the Choke is set to the fully closed position will it turn over and start. All other positions elicit turn over, but no start.
I'm happy to completely tear down the carbs again, but nothing happening appears to be jet or o-ring related.
Honestly? I'm to the point of flinching due to the red-line reving as I almost can't turn it off quickly enough once it turns over and starts. 😬
An update...
1. Change the Fuel **** into the 'On' position
Carb slide springs are it, there are no other springs
When you say "this hasn't overcome the reving nor the throttle handle 'snapback' issue" are you saying that you don't have throttle snapback? If so, you need to spend more time on the "everything is installed properly" statement because something is awry. You need to have the air cleaners off so you can clearly see the slides, making sure they go up and down at the same rate, there's no stiction, and they return to the carb bottom the same.
Stiction in the throttle grip itself would seem to be precluded if you are not giving it throttle at startup, which would be the case for normal electric starting, but starting procedures vary a bit. As others have noted it would be a good idea to ensure your slides are correct L to R and not backwards, also that your springs are properly seated in the bosses and not "cocked" in some way and that the carb tops are properly seated and that rubber gasket in its proper place before threading. These items are all a little finicky
I can't think of a reason your bike could rev to the moon if the slides are all the way down
All Hondas need choke to start when cold, and with the throttle left at idle or just slightly above. With your "elevated slides" situation it would be getting more air than typical so the choke would absolutely need to be full on to start, then reduced immediately as soon as it was running (when not doing a runaway idle thing).
Without seeing pictures of the routing and adjustment of your throttle cable, it's impossible to know what might be causing the problem. The slides have to bottom in the carbs, against the idle speed screws (not to be confused with the idle mixture screws, which are usually adjusted 1 or so turns out from gently bottomed) and there has to be a slight amount of slack in both of the cables attached to the slides to avoid them being held up off the idle speed screws. The use of the cable adjusters on the carb tops is how you synchronize them to lift at the same time, and there also has to be a little bit of rotational slack at the twist grip as well.
Appreciate the feedback and insights.
"I can't think of a reason your bike could rev to the moon if the slides are all the way down" I couldn't agree more! For all of the carburetors I've rebuilt (Jeep, Ford, lawnmower, etc...) I've never seen anything like it. Carbs can be finicky, but its not rocket science, right?
Wrt slide positioning, for each slide the concave bottom side of the slide faces air intake and each slide moves freely (up and down) in the carb bore. When I rebuilt the carbs, I did them one at a time, completing and reinstalling the first before tackling the second, to be sure I didn't cross any pieces/parts. As for the choke, I currently have the filters off and looking down the throat the chokes appear to be in synch, closing/opening properly.
It should be noted that the reving first happened while out on a test ride. Traveling along in 3rd gear when shifting to 4th it abruptly redlined. Turning it off and then restarting got me back to the shop. Since then it always redlines upon start. This led to new throttle cabling.
Tomorrow when back in the shop I'll grab some pics/vids and post. Hopefully you'll see something there that I'm overlooking.
I suspect the throttle cable. Yes, it may be Honda, but in reality, it Chinese copy. I've been smitten by "original style" throttle (and brake) cables.
I suggest disconnecting the throttle cable at the handlebar and starting the engine. If no high revs, then the throttle cable needs to be addressed.
If high revs happen with the throttle cable disconnected, then make sure the slides are properly installed. You should have two slots on the slide and they are indexed properly.
Then, if the problem persists, then make sure the throttle spring covers the index in the carb top. If the spring is not indexed the revs will happen.
Just my 2 cents worth,
I'm not really concerned about proper movement of the choke slides, but rather the carb slides themselves. If they are not going up and down freely with a twist of the wrist, therein lies your problem
Hadn't thought to simply disconnect the throttle cable thereby temporarily removing that variable from the equation. Theoretically, in this scenario the carb slide springs would force the slide to bottom position and *should* disallow the redline rev issue. And, assuming that that happens... I'm back to the cable as my culprit.
Not necessarily just the cable. (Although do make sure you’ve lubed the new cable well).
The throttle tube on these is another point of failure. They’re metal, and as such do require a bit of lubrication - they can also capture a large amount of gunk between the tube and the bar.
When you remove the cable, remove the throttle tube as well. Clean out the inside of it well and put a thin coat of grease in there. I like silicone brake grease since it resists dirt a bit better.
Make sure the little tensioner spring inside the housing hasn’t popped out of place and that the end of the grip is not rubbing on the end of the handlebar.
Great point, and by that he means this - #6, 11 and 14 are an old-school "cruise control" that was adjustable by loosening the lock nut (14) and turning the adjustment screw (11) inward to push on #6, which provided spring tension to the throttle pipe.
Update: Several issues were found wrt the new throttle cable; to include routing.
I'll upload some pics later but the net net from todays activities as follows:
1. The throttle handle now snaps back as intended
2. One of the two slide springs wasn't mounted correctly to the underside of the carb cap, showed a bit of damage (a slight bend mid-spring) and has been replaced
3. Slides appear to be moving as designed
4. Choke seems to be working
Also, per your suggestion EzPete I oiled the cables and dismantled, cleaned up, and silicon greased the throttle handle tube. As thought, there was some buildup there that could have been causing some of the sticking and contributing to the lack of snapback.
Starting up she no longer redline revs! (An absolutely huge win, tbs.)
However, now on startup she revs high and plateaus - at what my ear tells me is above 3500 rpm. Fiddling with the new cable i've got the slides moving in concert (Popsicle stick method) and reset the air and fuel mixture screws to factory settings.
More troubleshooting tomorrow morning.
Wrt the new throttle cable, beyond synching the slides, are there other considerations for a new cable install to which I should look?
Perhaps consider rotating each carb slide 180 degrees. Good to have the throttle cable concern behind you.
Wrt P&T, I did, however that was prior to the current round of carb fun. About a month ago I'd pulled the points plate and inspected the advance mech as part of the larger shifter lift rod swap and fix. Everything looked in great (almost new) condition. I'd set the points at that time as well - and put on a new cover/screws on. Likely need to revisit that again.
Wrt the idle adjustment screws, I didn't have time this morning. I'd set them to factory spec and started her up. She ran up to a fairly high idle and stuck there; a massive improvement over the previous redline idling. I assume that the mixture screw (currently 2 1/8 turns out) isn't allowing the slide to bottom out with the subsequent effect a high idle? In fact, that's what I *believe* I'm seeing looking down the throat; I could be persuaded otherwise.
Unfortunately had to run this morning and haven't tested the screws as yet.
Idle mixture screw won't affect the idle adjustment screw, back those adjustment screws all the way out and then take a look at the slides as you're showing here
To my rough eye it looks like your slides aren't low enough for idling
You may have the settings for the mixture screw and the idle adjustment screw combined.
Idle adjust is all the way out then adjust until you don’t need throttle to hold idle.
Agreed. Thus, my point that perhaps the slides are installed 180 degrees off. Now that you have a good pic of the slides turn one slide 180 degrees. I suspect the slide will rest all of the way down.
There is no rocket surgery involved in determining the proper direction of a carb slide
ancientdad's photo in post #24 tells the whole story: (1) the "cutout" must be to the rear of the carb and (2) the angled ramp that allows the idle speed to be properly set must be on the side where the adjusting screw is located
A reversed slide may allow the bike to start and run somewhat but it won't idle well and idle adjustment seems impossible likewise
To avoid confusion that may arise due to misplacing which carb is supposed to go on which side, or if using parts for which L and R are unknown, checking for the previously two cited conditions clears it all up
And I also said something similar way back in this post:
And since it was not responded to (and sometimes I suspect the method of mobile use is to blame, seeing only the most recent post), I still wonder if the idle speed adjustment screws have been turned in to the bottom and then backed out 1.5 turns or whatever the FSM says, like one would do with the mixture adjustment screws. Which would make the idle really high.
Today's update: Things are exceptionally better
As you can see from the pics, adjusting the fuel mixture screw out - significantly so - allowed the slides to further seat and get her to a place where I was comfortable letting her run until sufficiently warmed up. Both screws were set out 6 full turns (12 half turns) and, once the engine reached operating temp, then dialed back to ~4 7/8s turns to achieve initial tuned.
Note: I'm not sure how to post the video but I do have one of her warmed up and running at low idle.
I also took her out for a couple quick test runs to be sure things were working. So far, so good. Later today when back at the shop I'll try to tune her even more to be sure through all ranges she's not bogging or sputtering.
More to follow.
THIS is exactly what my post immediately above was about - when we all use the correct terminology, we all understand what is being discussed. I tried to make the comparison to the mixture screws in my post above in vain. What you adjusted that allowed the slides to drop further toward the seated position is the idle speed screw. And, this is why the parts fiches are so helpful, because they give you the name Honda gave the part which is, for the most part, the terminology we use here so we're all on the same page.
And this above is why I constantly ask if new members have seen the Welcome Package, because many things like this are fully explained so new members don't have to ask many questions. we do not host videos here to save our precious, expensive server space for pictures so we can all see what the member sees.
Upload your video to any free hosting service (YT and the like) and link it here.
Just to make sure everyone is speaking the same language.
This is the idle adjustment screw that allows the slide to drop the further out it is.
This is the fuel mixture screw.
The goal of the fuel adjustment screw is to get the exact mix at idle. If backing that out reduces idle speed, you’re over-enriching the mix.
If it’s actually the idle adjustment screw, that’s the correct one. You bring it down to a correct idle speed there, then adjust the mixture to raise the idle speed when the bike warms up, then reduce the idle speed adjustment screw to bring idle back down with the correct mix. Then you’ve got the correct mixture and idle speed and can ignore that whole thing and just operate with choke on colder mornings.
At the risk of being pedantic, I'm compelled to note that, for me anyway, any notion of how many turns in or out a screw should be does NOT pertain to the idle adjustment screw. They are set to achieve a proper idle RPM, period. I have never checked nor have ever been interested in how many turns out the screws are. As far as adjusting EACH idle adjustment screw for the purpose of synchronisation, that is another skill that needs to be learned.
Yessir, that was yesterday's vid and they were indeed slightly out of sync. I messed with it a bit this morning and then took her for a short ride. I still think the left is firing slightly in advance of the right but everything seems to be operational throughout the power cycle with gearing operating as intended. I'll continue to dial the old girl in as I focus on other items she still needs: badges (both sides), covers (both sides), some seat work, mirror mounts are stripped, etc.
Also planning to go back and again gauge everything jtbs.
I still think the left is firing slightly in advance of the right.
This is unpossible for single points that fire both spark plugs simultaneously
I assume you are alluding to the carb that is set at the highest idle setting, as compared to the other carb, is "running the show" but that is easily remedied
Yeah. That’s just idle speed setting. Best done when the bike is all the way warm - easy enough to do and you can usually tell which side is running harder because that header will warm up faster.
