Have been advised to do a log of my engine strip down.At this point it worth some back story.
I have had a lot of problems setting this bike up since I have got it as a non runner .
One of the things was setting up the carbs .. now I'm thinking one of the problems I had was the engine .
when starting up it was fine . 10 min in to balancing carbs I had issues and taught it was either me or the carbs
After getting every thing close to perfect I took it out . 2 miles latter I it limped home and I could tell it was hotter then it should be ...
So .the strip down .
I had a suspicion that the top end wasn't getting any oil. Removing the left hand side head , showed some scoring both to the cam, and the LHS head.
Working my way down as you can see from the cam, it's showing signs of heat damage .
throw to the head and barrels it's clear some one has been in here before
Gasket selent was blocking up mostly the RHS of the oil pathways . But also one on the left.
And also one of those little little rubber things that holds the cam chain tensioner in place was missing .( Was ok thow excess gasket selent was holding it in place )
At this point it made sense to strip down the bottom end as well and this is what I have found any advise is welcome
The good bits..
From what I can tell the bearings and the tolerances in the crank are fine.
Every thing has a clean amount of oil were you should expect. As is the 2
sets of gearing and the rollers on the end . I haven't striped any of them
down. Just had a good look in my hand . Not sure if there is any need to do
so ? There is no sign of heat damage , excess play, issues with
the roller bearings.And the kick starter shaft is still in place . There w
as a little play it in . But wasn't leeking before the strip down
The bad.Some one has put some centre marks in the casing . More on
the bottom aiming inwards so I Imagen some one has had some issues with the rubber seal (photos )
the seal it self has damage and although it wasn't leaking I think I best find a new one .After an
epic battle removing the 2 bolts on the oils tray and a waste of my time ,
realising after that I can't remove it . I can't really get at
the sludge beneath.=I have it up at just over 90' and the sludge is slowly flowing out.
Hopefully overnight most will be out . And maybe I will
have my missing rubber cam pice as well. But I think I will have to re make that one .
All ports seem clear . And I think with some gentle sand papering skills I
can remove the worst of the highs from the centre punch marks .before the rebuild .
For cleaning up . Am I best to try and jet wash under the oil pan then put some de greeser in a tub and take my time with it .
Drying it all out and then applying some wd40 to try and stop any flash rusting?
And also any ideas what these seeles are for in my gasket set ?
any thing I should have a closer look at ?
Thanks in advance
The good bits..
Thanks in advance
