infinitiy
I am hoping someone can point me in the correct direction. Garage kept 78 CB400A and I run w/o a battery, which the cause of this is probably why I do.
Today I run w/o the battery and last fall I noticed my turn signals would only work when stopped and in gear, or throttle<25%. Headlight & marker lights work but dim when blinking. They used to work fine(with dimming) w/o the battery. Otherwise the bike runs great.
Hooked up my DMM to the source wire of the flasher and frame and got 7-8VDC at idle. Same at the battery connections. Thought maybe the rectifier was on it's way out and got a new one. That made it worse, there were no turn signals at all. I checked the three yellow wires from the Generator and DMM said 1.1ohm between each combination. I know it is supposed to be between 0.2 and 1, but that is with that particular VOM, so I figured it was ok. Out of interest I switched to VAC and on the yellow wires and got about 10VAC for each combination.
Looking at the wiring diagram there shouldn't be anything that would drop it 5V.
This is then why I run w/o a battery, It would never stay charged and throwing the trickle charger on it all the time was being hard on that old plastic cover's attachment points being on/off. Eventually the battery went bad from being so low and I never bothered to replace it.
Thoughts?
Infinity
Thoughts?
Infinity
