Santiago
Thank you, that would be appreciatedI have one at home. Can measure tomorrow.
Thanks G-Man, much appreciated.CB450 Con-rod
Big end 39.0 mm
Small end 17.0mm
Centre to centre distance 168.25mm
Width 18mm
Here is a trick for installing the bearings. I believe credit goes to the late Bill Lane for this video.Oh I did take the end roller bearing apart to clean it up and what a joy that was to get all the roller pins back in their cage.... kinda like herding cats!Heavy grease is your friend here.
Brilliant!Here is a trick for installing the bearings. I believe credit goes to the late Bill Lane for this video.
No cigar on that one. The centre bearings outer shell will move about 2 mm before hitting the tang stop and the aluminum roller cage won’t move away from the crank weight at all. I cannot see anything down there at all against the inner weights, there is nothing to move away to get anything in there.Sounds like all the sediment is your evidence you've done your due diligence.
By the looks of the picture, it still looks to me that those center bearings will slide towards the center partially exposing the rollers and cages and also exposing the edge of the sludge traps.
Did you try standing the crank on it's end and running WD40, whatever from the center to see if it oozed out the rod big ends? That would definitely be as good as it gets.
If you do stand it up, duct tape that loose bearing so you don't loose your meatballs.![]()
I knew that video was out there, though I think Bill Lane only referred people to it based on the YT channel name. But it's certainly a genius method.Here is a trick for installing the bearings. I believe credit goes to the late Bill Lane for this video.
This is what I was thinking. The ones on the right are closer to the pump, so smaller to give enough pressure to the left?Probably to restrict flow so the head and cams get enough. Make sure there is flow from the sludge traps to the big ends. I'd stand it on each end and let gravity show you while flushing.
Stand up the crank vertically on end then the WD should flow through the counter weight and the rod pin and out around the rod bearing. Plus, you can spin the rod as the crud works it's way out. Then you know for sure it's open all the way to the rods.I spent some quality time with the crankshaft and really looked carefully in the centrifugal oil cavities. There was a lot of light gray glop in there! I dug out what I could and rinsed them out with WD-40, then set out to find the oil passages to the big ends of the connecting rods. It took a lot of messing around with lighting and peering in from all sorts of directions before I saw one, fed in a squirt tube and blasted a lot of WD-40, until it came out reasonably clear. Found the other one and did the same. Tomorrow I'll squirt them again.
Thanks to everyone for pointing me in the right direction.
I'm looking at the crankshaft in my K0 now, too. The oil passages from the block to the bearing holders are all different sizes. They are all clear and the sizes are in the metal, not the result of accumulated junk. In photos of the crankshaft on another K0 at the beginning of this thread I see that variation as well. Why aren't the openings all the same? These photos show the 4 oil passages, engine left to engine right.
The Bernoulli effect at work here?That puzzled me as well, but it doesn't make sense to think that this will influence the flow because the real restriction is the opening to the bearing surface, and those are having more or less the same diameter. And since that diameter is much smaller than the opening you point out with your pencil, fluid dynamics is clear about it. Since the ratio in diameter between the large hole you point out and the diameter of the bearing surface is larger than a certain value, the smallest hole (in this case the diameter of the oiling hole at the bearing surface), the diameter of the large holes you point out, even with this difference in size doesn't have much influence on the flow.
I don't know. Maybe you got to die first before graduating from principle to lawWhen your fitting loose rollers into cage and think they may fall out during assembly, use Vaseline (petroleum jelly) not grease as it has a much lower melting point so clears out quicker and easier.
Isn't it the Bernoulli Principle and not law?
Used to teach it as part of how carbs operate
It would be a principle, derived from or explained on the basis of laws like Newton’sWhen your fitting loose rollers into cage and think they may fall out during assembly, use Vaseline (petroleum jelly) not grease as it has a much lower melting point so clears out quicker and easier.
It's not easy. Post #119 showed one approach and later #121 shows how plugged they can get. Oil must get from the centers through to the large end rod bearings, I eventual got WD40 to flow through but a lot of crap came out.It's interesting that the 4 speed engines use a different way of securing the bearings of the crankshaft to the upper crankcase. The shaft itself looks very similar and the oil circulation seems the same.
How do you know when you're done with the cleaning?
Same here. The stuff that came out was light silver gray - aluminum color. It did make it easy to see when it ran over the crank, so I kept doing it until I ran the WD-40 can too low to work on the angles I was using.It's not easy. Post #119 showed one approach and later #121 shows how plugged they can get. Oil must get from the centers through to the large end rod bearings, I eventual got WD40 to flow through but a lot of crap came out.
I think we have to face up to the fact that our normally robust, invincible Honda motors, after 50 or more years need extra help if we expect them to hold up after our expensive and labor intensive builds. My last two scuzzy barn find builds had serious ring, cylinder and small end rod bushing wear, which means the two notches in the edges of the con rod big ends aren't splash feeding the way they should.Same here. The stuff that came out was light silver gray - aluminum color. It did make it easy to see when it ran over the crank, so I kept doing it until I ran the WD-40 can too low to work on the angles I was using.
