Danager4792
1971 CL450-K4 w/ 5,098 miles.
Backstory: In 1983, an 85 year old man dropped his bike off at a motorcycle shop in Michigan. Shortly after, he passed away. The family had no interest in keeping the motorcycle, or paying the shop fees, so they gave them the title. It sat in the corner for 40 years. New ownership took over this shop recently, and decided to sell it. The next owner was a man 45 mins from me in TN. Due to his wife developing an illness, he only made it to buying new spark plugs, and a battery(that is too large for the frame). The bike came with a box of spare parts(pictured below). There were zero records about why the bike came in the first place, or what the shop had done to it 40 years ago.
1st I checked compression. Cold engine, with marvel mystery oil, 140psi both sides. He then poured gas into the cylinders and the bike did fire up for about 2-3 seconds.
Getting it home I started to notice things, such as the right air filter and case missing, Honda emblems with broken pins, mismatched colors on mirrors, very torn seat, and black crankcase covers.
My goal: Get the bike back running mechanically sound (fuel, air, spark, engine tuning) and worry about cosmetics later. I do not have much experience mechanically, but this will be my first bike to learn on. The bike will most likely be sent to my mechanic friend to do the brakes, suspension, and tires. And any advanced engine tuning. I would also like to piece together what happened to this bike before, and after being at the shop. To figure out it’s story.
This is what I’ve done so far:
I cleaned out probably 90%-95% of the fuel tank rust, and got a new gas cap since the old one was loose and the o-ring was dry rotted.
Next I pulled both of the carbs, they were very nasty on the side. I disassembled them, ran the carb bodies through an ultrasonic cleaner, then installed all new internals. The floats had ancient gas in them, so I replaced those too. For the rest of the fuel system, I also bought a new petcock valve, and new 5.5mm fuel line.
Next, I cleaned the oil filter, then changed the oil. While doing this, I also installed all new o-rings, even for the dipstick and drain plug. I noticed the right crankcase gasket looked terrible, so I changed that out too. I went with SAE 10w-40 oil, seeing that’s what the dipstick cap says. But after searching this forum, I will be switching over to Rotella T4 15w-40 conventional with the added zinc. Upon cleaning the drain plug and filter, I did notice shiny metal glitter and debris.
Currently typing up 2nd post
