Just wanted to wrap up some loose ends on my project. and give some updates on where I am on this project.
1. I tried clearing out the gas cap vent but could not clear it, The ebay cap that I bought works great though so I kinda set this aside for now.
2. I have gone 100 miles on the motorcycle now, and the crankshaft oil leak has stopped leaking. I did not do anything since my last post other than ride it. It stopped on its own.
3. Sunday I replaced the fork seals and refilled with ATF, (That is a dirty, messy, smelly job) they now look better and work much better.
4. I made an adjustment to the fuel mixture and went for a ride, After a few miles I was getting some weird idle symptoms. I went back home and started checking things. I thought maybe my mixture adjustment threw something off, so I set it back to where it was. (Turns out that this was unrelated... but I will get to that) Anyway while idling I pulled the sparkplugs off one at a time and found that right cylinder was not firing, or at least very intermittent, but it would kick in if I gave it some throttle. I pulled spark plugs and tested each one and swapped them to see if anything changed and what I noticed was a very weak spark on the right side. The right side spark plug wire seemed to be the issue, so I removed both Wires and proceeded to resolder them both. Well they were never really soldered to begin with (just crimped) so I soldered them, I did find the right cable had a poor connection to the spark plug cap, which was likely causing my weak spark. Re gapped the spark plugs to .035 (Dyna Coil....ask
@Maraakate ) Then rechecked Spark.... All good now. Started it up and still getting some fluttering and spitting which I am contributing to the right side cylinder. So I tried not to panic and took a day off to think about the problem.
Next day what I came up with is I am going to pull the gas tank and recheck the valve adjustments. I reset the valve clearances, (right side Exh was a little to tight, but everything else seemed ok. Set them to .006 intake, .008 Exh a little on the loose side as was suggested on here. Then I had another thought related to the throttle plates in the Carbs, Remembering that I bench synced these and tried to get both throttle plates to completely close at the same time, but with these symptoms I thought it might be possible that the right carb is choking off too much air at idle, but it recovers once you give it throttle. (So some of you guys are going to say DUH you need to sync the carbs on the bike), well I don't have a sync tool at the moment, but I thought since I already have the tank off I will try to do it by ear.
I made a note of the starting position of the sync screw, then loosened the lock nut, started the bike set the idle rpm screw to idle at about 1200 rpm and slowly turned the adjustment screw back and forth to find which way it was going to be happy. I was glad to find out that opening the right side throttle a little is where it was happy (confirming my suspicion). I went back and forth a few times turning the sync screw, then back down the idle screw until I felt it was sounding good. I then put everything back together and went for a ride. It is much happier with this adjustment and the idle has significantly improved. less than a 1/4 turn is all it really needed.
Things next on the list to do.
1. Rebuild front brake caliper. (already cleaned up and re-assembled, but leaks fluid. Parts will be here this week)
2. Find or Make a air box lid. not happy with the ebay prices for a full airbox assy. I just need the lid.
3. Fix Battery+ connection. I have a non standard size battery so I need a different wire to put everything back to stock location. Or just get the right battery...
4. Properly route wire harnesses/cables to correct locations.
5. Fix tail light housing with epoxy paste and threaded inserts, Like
@Slofun did! (or get a cm400t tail light assy, since I don't have a grab bar to mount the rear turn signals. I have them mounted in the fender holes.)
6. Missing the "GRAB BAR" that mount around the seat. I keep looking for a "DEAL" on ebay.
7. Repair the original seat. I have the original seat frame with the old foam. it will need some work and a seat cover.
Edit:
8. And a better fuel line setup with filter.
