Hey @Maraakate,
I'm not sure why the OEM trace set looks cleaner at this point. These tools are all new to me.
I will be re-doing some comparisons. I am making a better wiring harness for discount CDI.
This initial one I had the discount CDI mounted away from the coil by the fuse box, new harness
it will be placed directly under the OEM CDI making it a more fair comparison, and more easy to
switch from one to the other.
I am not a ham but I have total respect for that. When I was about 10 years old I got a 200 in one
Radio shack experiment kit and making a crystal radio was a favorite. Forest Mims did some great
educational writing for Radio Shack.
For the OEM CDI I managed to clamp the amp probe around the hot(yellow) wire going from CDI to coil. For discount
CDI it was a very long run of wire. So yellow is trace from high voltage spark plug cable with
this hantek capacitive clamp on spark plug wire. I also got a 20:1 attenuator from Hantek,
but it didn't seem needed at first try with spark clamp so just went direct with that. Not sure if it has
much attenuation built into it, it does have a small box that might have some electronics.
I think it is fairly simple and just a raw wire put next to spark cable could work as well, I have seen
a few you-tubes that suggest this, and people making there own simple pickup probes. It's a little
concerning that it could hurt the scope, but whatever, it's not that expensive.
The blue trace is the current clamp. It has two settings, 1mv per 10ma, and 1mv per 100ma. Something like
that. So at lower setting, 1 volt difference should be about 10A. We do see about +-.7V swing, so it would
be around +-7A. I have learned from others that 4A to 8A is typical of what goes thru primary.
So I made a minature gas tank for testing.
It's chrome! Pretty cool huh? So I'm trying out my new
mini gas tank, and low and behold gas spews out the overflow bowl spout. Hmm, I've been riding this
and have not noticed a problem, but I suppose it could overflow and I could be none the wiser as it sprays out
into the wind. Now after a while one gets clued into the fact that these bowl gas flow stops can be
a little flaky. So I made this super cool overflow detection sensor.
Now the gas can has a top. I've got this old school can opener that gives a clean cut of a can top
so the top is still usable. Coolest thing ever.
Idea is that at end of driving I can look at it and see if any overflow occurred.
Another random tip - To get pictures off phone wirelessly from Android phone to PC I use Android free
app Amaze and it's FTP server feature. Then on PC I use another free app called WinSCP.
