I doubt you have a leak, more likely grease the previous owner slightly smeared to prevent rust or allow easier disassembly.
If the center screw between the studs is dry, it is the hole plug removed when draining the fork oil fluid.
The holes the 2 studs for the fork holder screw into are likely bottomed with no connection to the fluid chamber...
