Khoa360
Hello all,
This post is dedicated to our Honda CB360 project that we picked back in late September of this year. Our bike has gone through two owners, with the first owner riding it from 74 all the way to 85, where it was parked for unknown reasons. Fast forward many years later, the second owner has attempted to get it to run again and let a shop handle the repairs necessary, which includes repairing the starter motor, cleaning out the gas tank, installing a new solid state regulator/rectifier unit, and rebuilding the carburetors. The second owners had plans to turn it into a cafe racer but changed his mind and listed it on Marketplace. When we came to view the bike, however, the bike refuses to run, which we later discovered was because one of the wire leading to the condenser was broken. Overall, the bike does look really good with minor surface rust and we were able to negotiate a deal.
The bike when we first arrived, those upswept exhaust really caught my attention!
After we loaded it onto the back of our truck
After we got home, we started to work on it and made a few discoveries upon closer look:
- The front brake sensor switch was cut & removed (luckily enough, when we purchase the lower left switch housing, it comes with the sensor for the neutral safety switch, which we repurposed to be the front brake switch)
- The bike have been dropped, causing the lower triple tree stop to break and dented the gas tank. We're not sure if that's also the reason why the left mirror mount is broken as well, but that might be the case.
- A lot of screws heads are jacked up on left side of the engine, most likely because the shop didn't use JIS screwdrivers to remove the screws. Furthermore, some screws are protruding out, indicating that they didn't keep track of screws length.
- Tachometer cable screw is stripped badly and outer cable cover is damaged, seems like someone tried to replace it without any success.
- Horn isn't working.
- One of the fuse in the fuse holder isn't secured properly.
- Terrible fuel line job.
It definitely is quite the list, but one by one, we're addressing the issues we've found and hopefully somewhere in between, improve it so it can be a decent rider. As of right now, we're working our way in the front area of the bike and are ready to put everything back together soon.
As for our plans with our bike, we're planning to:
- Upgrade to Electronic Ignition (debating between Shockwave and Charlie's Place)
- Lower the handlebar (although unlikely, as we really like how the stock handlebar looks)
- Fitting in a crash bar and rear luggage rack (trying to work a deal with a fella who wants to part one from his CJ360)
- Repaint the side covers to either black or the factory color.
And that's pretty much it for now, thank you for stopping by and reading my progress report
The bike as it is, still the same as the last time I've wrote about it
