Flight Risk
So, because confidence is something that you have when you really don't know what your up against. I barreled straight into dismantling the front and rear wheels because I had time (this was a few months ago). If you have read my build page, then you know that I had to replace three bent spokes in the front (2 inners and one outer) so I bought 2 sets of NOS OEM spokes (the right part number) off of e-bay.
I watched several videos and bought a truing stand (and borrowed a warp9 torque wrench). I can get the wheel pretty true at low torque, but when I do the slowly torque every third spoke to spec (I'm hoping for about 15 inch pounds when torqued up), it goes out of true (both up and down and left to right) (Problem 1).
A couple of the spokes (both outers on the same side and in sequence (ie. 4 holes apart) both protrude really far (like 3 threads up the rod) into the tire. One of them actually ate through the rim strip and started a slow leak in the tube (problem 2).
I was told that this was probably a problem with the offset (referred to as the disc by a local guy who builds lots of these) and that I should make sure that it is in spec. So, now I realize that in my rush to get started, I never measured the horizontal distance from the edge of the hub to the edge of the rim.
I'm not sure what to think, yes, more outer left side spokes protrude from the nipples than any other type, so maybe the offset is wrong, but nowhere in the service manual that I have does it mention an offset. Does anyone have insights, advice, or table measurements (measuring front rim distance from bench while lying on each side (without speedo unit and without brake unit). Hopefully someone smarter than me did these mesurements and still has a record of it for a 1968 or 69 CL450 (drums front and rear).
Thanks
Thanks
