Hello good people. I'm looking for expert advice to solve issues with my carburators on CL175 (1968). Couple of problems,
1. Idling not always the same, it could die easily or some times engine is hunting. It gets better after run, but in my view bike only really goes in forth and fifth gears. In first and second it is in my opinion lacking power.
2. I changed sparking plugs for new one and noticed a black deposit on contacts. So I did followed an idling instructions ( adjusting throttle and air mix screws together) but I wouldn't completely happy with the outcome neither.
3. Adjusting idle revs seems to be only possible with Left Carb. On the Right Carb. adjusting the throttle screw doesn't make any difference.
4. Normally after run, Right Carb. has some oily petrol smelling bleeding on front wall of float chamber( see photo). I suspect a floating chamber washer but haven't yet removed clip to open up a chamber.
Otherwise both units are looks brand new and very neat. I'm sure it can be resolved, but unfortunately I'm not a qualified mechanic )
Thank you in advance
