CB450 Headlight question
boddy
Hudson, Quebec, Canada
I have the 7" headlight on my CB450 and was thinking of getting this halogen assembly. My question is does this 35/35W bulb generate a lot of heat, should I be worried about melting any wires in the headlight bucket?
thanks
I can't see any problems with you running that 35/35 halogen bulb in a 7" headlight. I ran a 60/55 halogen bulb in my Gold Wings and CB750s with the 7" case and never had any issues with heat.
Thanks for the confirmation, I will go ahead and order one.
I was looking at the same part from CMC and came here to see if anyone has found it less expensive from a different vendor….
I ordered a light through 4into1.com. Looks to be the same as CMC but for $25 less.
I meant to get back to this yesterday - but I wasn't sure if you meant the entire assembly, or just the H4 bulb. Either way you saved money, which isn't difficult outside of CMC's orbit. (y)
I had initially thought the PO had upgraded the “lense”from the sealed unit, so I ordered the LED bulb from Sparck moto. Then I took it apart to discover it was not ungraded! My fault lol. So I really just needed the new lense which will accept the newer style led bulb.
