Yesterday evening I had an hour spare, so back to the garage and disassemble the cylinder head. In the past I disassembled many 250 / 305 heads, and learned a few things on the way. Normally, when the head is never touched by a PO, it can be quit challenging, especially when moisture or high mileage are part of the deal.
In this case someone was in the head in an earlier stage, plus the bike stood in a dry, relative warm environment, so the job was easier then normal.
Starting with the ignition cover. I secure the head on wooden blocks with the back against the wall (protected with a piece of wood), this way I can push the (JIS) screwdriver really hard into the bolt with my sternum (I made a special piece of wood where the end of the (JIS) screwdriver is centered, dividing the pressure over my chest). Now I have two hands free, one to hold the screwdriver, the other one for tuning the screwdriver with a wrench. I could do it with a impact driver, but since the aluminum threads of these heads are vulnerable and sensitive for shock-load / impact, I choose not too if possible.
In these bikes, the camshaft is composed of three parts, the left- and right camshaft, and center sprocket. The advance mechanism, including the springs are build in the sprocket, thus if you have to replace the point shaft, or the advancer springs you have take the engine out, remove the top cover, etc. Not a wrench friendly solution, that's one of the reasons to avoid using the advancer and use an electronic ignition (Sachse) with build in electronic advancer. However, I keep the points-shaft and springs in place for points ignition when needed when the electronics break down.
All bolts are spared, and re-usable after cleaning and re-plating.
Like pointed out earlier, the points are not in a healthy state and are being replaced on the spare points plate.
The backside revealed black dust, this can be particles of plastic from the points (likely), coal from the exhaust fumes (unlikely), rubber from the oil-seal (likely) points-dust due to a bad condenser (most likely). I have to analyze this further to get to the bottom if it, never seen that in this amount.
The other side came loose too, and again all bolts are saved and re-usable after plating.
As you can see in the picture below, Honda-bond is used in huge quantity's, luckily it's Honda-bond and no silicon gasket. I had some issue's to get the follower shaft out, Honda-bond was applied there as well.
Unfortunately, all four valve covers are damaged, either by the PO or by me. After taking these of with heat and a chisel I saw why these were so stubborn. No O-rings were used, but instead, a large amount of Honda-bond on the surface AND thread did the trick
Once the head is off, there is no easy way to hold the camshaft from turning to get the bold of the clamp mechanism from the clamp bolt at the tacho side.
The easiest way I found is to use the cam-chain itself, works always like a charm. Now the camshaft is secured, the nut at the end of the R/H camshaft can be loosened.
This is the nut, and secures the clamping bolt. In most cases this nut is tight, very tight, also at this bike. After loosening, the bolt has to be hit with the nut still on it (to avoid damaging the internal advance mechanism). Before hitting the nut you have to secure the camshaft sprocket too, otherwise the whole camshaft will move, including the bearings, and that is something to be avoided at this stage.
I place a heavy piece of copper on top of the nut and give it a punch with a steel hammer, in most cases the bolts will come loose after one blow. As you can see in the picture, the bolt came loose, and is resting on the nut. I sprayed a lot of penetrating oil around the threads of the cam sprocket nut, because I think it will not give up without a fight (this will be one of the few times that you'll see me using a hammer).
Next step is to take out the camshafts, remove all valves, and decide If I can re-use this head or pick another one out of my stash. Enough too choose from, 40+ cylinders and heads available from all years.
It took a lot of work to categorize everything, but now I can make a picture of the CB72/77 and dream cranks in one place. every box contains 3 complete (used) cranks, and there are six boxes. Every crank is labeled, and there is a short description per crank of engine number, general state and a measurement report. With my press, some guiding of G-man for the tricks on these cranks, and some machines around me, I don't have to be bored after my retirement
