The bike had not run in sometime. Rusty tank, leaks, and neglect. I've spent a few months bring it back. Cleaned tank and repaired leaks, rebuilt petcock, replaced one points and set timing, carbs cleaned and new gaskets installed, filter cleaned and new oil added. Synced throttle cables, set idle and air fuel mixture, etc..
The engine idles smoothly at 1100. However, when I accelerate each cylinder individual the left engine responds slower than the right. I get a quick and immediate on the right side but a hesitation and then slower response on the left. Using the hand grip throttle to bring up both engines at the same time the response seems normal. All this is being done with the bike on the center stand. No load.
Any ideas?
Any ideas?
