Results 1 to 6 of 6
Thread: Manual piston ring file
  1. #1
    Senior Member Juneaudave's Avatar
    Join Date
    07.20.20
    East Helena,MT,USA
    Posts
    466
    Thanks Thanks Given
    132
    Thanks Thanks Received
    216
    Thanked in
    I need to set the gap on a set of new rings. Can anyone recommend a good (functional but inexpensive) manual ring filer? I see them in a wide range of prices from $25 on up, and being sold everywhere from Amazon, eBay, JEGS, Summit...etc. It's something I've never done but seems like a worthy skill to have.
    1972 Honda CL350 K4
    Original air box
    Points ignition
    1971 Honda SL350
    Original air box with foam covered filters
    Points ignition
  2. #2
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Dave, I've always just used a thin flat file clamped in the vise and carefully filed the ends by holding the ring on either side of the gap and gently moving one end up and down over the file while checking the results often. I've not done it often enough to worry about looking for one specific to the job.
  3. #3
    Sensei 66Sprint's Avatar
    Join Date
    05.22.20
    Roanoke, Virginia
    Posts
    2,022
    Thanks Thanks Given
    17
    961
    Thanked in
    A cheap set of "jeweler's files" from Harbour Freight contains a good file for this......
    Contact info :
    For e-mails; [email protected]
    To send donations to the cause or towards my phone bill by PayPal, please use [email protected] to identify my account....
    Please include your vintagehondatwins username so I know to whom to send a thank-you ....
    Phone: (540)-525-5199
  4. #4
    Join Date
    07.20.20
    East Helena,MT,USA
    Posts
    466
    Thanks Thanks Given
    132
    216
    Thanked in
    Looks like a small file is the ticket! Thank you!
    1972 Honda CL350 K4
    Original air box
    Points ignition
    1971 Honda SL350
    Points ignition
  5. #5
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Quote Originally Posted by Juneaudave View Post
    Just be very cautious and go slowly, they can change a few thousandths in a hurry.
  6. #6
    Senior Member
    Join Date
    05.31.20
    Calgary, Alberta, Canada
    Posts
    551
    Thanks Thanks Given
    4
    269
    Thanked in
    I use a diamond disc for a dremel tool clamped in a vise and do both sides at once which keeps then square to each other. I also drag the front edges slightly as they get very sharp and can score the cylinder when doing a gap check.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
