Results 1 to 6 of 6
Thread: A very interesting brake failure story
  1. #1
    Senior Member
    Join Date
    10.30.21
    Ocean City, NJ
    Posts
    136
    Thanks Thanks Given
    6
    Thanks Thanks Received
    21
    Thanked in
    So my buddy is having some problems with his CL350, but we decided to ride around a little anyway. We have been having some problems with idling, however we did not expect this.
    He was braking at a stop sign, heard a click, and looked down to se his rear brake rod and arm had wrapped around his wheel.
    IMG_4176_result.jpg IMG_4177_result.jpg IMG_4179_result.jpg IMG_4181_result.jpg IMG_4180_result.jpg
    Our working theory is that the black control arm at the bottom became unfastened due to a lack of a cotter pin. Previous owners fault for not properly reinstalling the brakes, even more our fault for not properly checking them.
    Amazingly, we were able to unravel it with only pliers and a screwdriver, and walked his bike to a friends house that had an old little honda he was parting out. I think it was a ct90.
    Now he's got a baby brake arm! Works good enough until we can get a new one.
    1973 CB350
  2. #2
    Senior Member
    Join Date
    12.21.22
    Gettysburg, PA, USA
    Posts
    255
    Thanks Thanks Given
    77
    109
    Thanked in
    I totally understand the urge to take a spin, and applaud the ingenuity of the fix, but those Dunlop Qualifiers... just how old are they?
    1982 Honda CM450E: Fr:Shinko 712, Rr:IRC DT II, CM400A center stand, Hagon shocks, Wirth 6010-10 fork springs/Bel-Ray 10W fork oil, Texavina seat, Dime City elec tach, ATC Fuses, Emgo RH multi-switch & Classic bars, CmnMtr Vintage Rect Mirrors, Biltwell Renegade grips. I have the FSM
    2000 Honda GL1500C : Ikon Dial-A-Ride shocks, National Cycle windshield, Wolo Bad Boy horn
    Gear: Arai Signet-X helmet, Z1R Gust mesh & Joe Rocket Atomic 5.0 Jackets, Icon 29er mesh & Savior heated gloves
  3. #3
    Benevolent Dictator ancientdad's Avatar
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    19,119
    Thanks Thanks Given
    3,511
    5,042
    Thanked in
    I've seen it many times, and the damage that can occur can be a lot worse. I once had a worn out set of rear shoes allow the brake cam to open fully flat between the shoes, ending in total lock-up and a broken backing plate at the torque strap bolt and the same wrapped-around-the-axle situation. It can be scary if you're going fast enough, glad this one happened at low speed. That said, did you have another shouldered bolt for the torque strap to backing plate attachment point? Or were you able to find it? Oh, and BTW, his braking force will be reduced with the shorter arm as well.
  4. #4
    Senior Member
    Join Date
    10.30.21
    Ocean City, NJ
    Posts
    136
    Thanks Thanks Given
    6
    21
    Thanked in
    Quote Originally Posted by KenCM450 View Post
    Very old. And its a harley wheel on the back. It's all on the list to be replaced!
    1973 CB350
  5. #5
    Senior Member
    Join Date
    10.30.21
    Ocean City, NJ
    Posts
    136
    Thanks Thanks Given
    6
    21
    Thanked in
    Quote Originally Posted by ancientdad View Post
    We were able to find the bolt, luckily. It looks new because the nut was MIA. And I thought his braking power might be reduced because of the arm, good thing we are just taking it on short rides right now. Honestly, before we found the CT90 part-out, we weren't that far from his house and I told him just to run it just with only the front brake. Maybe my the confidence in my CB350G's disc brake was getting to my head! Probably better we found the arm.
    1973 CB350
  6. #6
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    19,119
    Thanks Thanks Given
    3,511
    5,042
    Thanked in
    Quote Originally Posted by kaidemarco View Post
    I've ridden many, many miles with a less than 100% effective rear brake before, the front brake does 70% to 80% of the stopping effort so a short ride without the rear brake would have been fine as long as he is well-versed in front brake usage. Glad you found the shouldered bolt, going with a standard bolt is just inviting that to happen again later. As for reduced leverage with the shorter arm, as long as he is aware and can compensate properly with more foot pressure he should be fine, but he should also avoid any high speed activity between that and those old tires.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
