CheeseGromit
Hi all,
We are in the process of setting up idle/mix, and one tutorial that I watched (for a CB350) shows how to do this by essentially starting the bike, then removing one plug and working on the running side and vice versa.
My question is, should the CB250k4 idle on just one cylinder ok? We are struggling to get it to run on just one cylinder, and before we dive into why, I wanted to check whether this is normal behaviour or not first?
It can run on one (ish) if the throttle is played with, but I assume that is maybe due to coming off idle jets?
Thanks!
Thanks!
