GaryJames
I have always shied away from anything to do with spokes but this time I decided to give it a go.
First side lacing didn't go so good as I got all the way around and I was one hole out so out they all came and try again.
Turn the wheel over and do the other side:
Then axel through the wheel and into the vice to true up the out of round first using a DTI magnetic base on the vice rear anvil.
After about an hour of fiddling about a bit here and a bit there I got out of round to under 40 thou which I think is okay according to a US based older guy on Youtube
who apparently does lots of motorcycle wheels.
Then DTI'd the side run out and managed to get the also to under 40 thou....
Then on with the tyre.
This pic is sort of showing how I used the DTI.
Only problem was after pumping up to 33 PSI the tyre was not setting evenly around the rim and had introduced serious out of round again! I had to let some air out and manually encourage the low areas up the rim.
Eventually it seated okay.
Using Shinko ribbed 3.00 as front tyre.
I will post on the rear wheel build later.
I am happy but proof will be when venturing out on the road..
cheers
Gary
cheers
Gary
