GaryJames
Completed the engine rebuilding on the bench. Barrels seated nicely after getting the bottom O rings in their grooves. this also made it easier to get the cam chain and sprocket on and sitting at TDC. Then installed the Valve pins, my new Rockers, adjusted the valves, top caps on and torqued the engine studs so now to to put the lump back in the frame.
I had to think about this for a bit as It was going to be a one man job.
Contemplating the frame I decided that since the wheels were off, to remove the foot peg bar, fold up the main stand and lower the frame to the ground. This would mean I only have the thickness of the bottom tube to lift and manoeuver the lump. Not wishing to damage my shiny black powder coating I wrapped the bottom tubes in Masking Tape.
The process went surprising well and I had completed it in 20 minutes....
( can AD rotate this pic please? it refuses to upload correctly even after I have rotated it on my computer.) - Done
On the bench
On the floor
In the Frame, engine was tilted back to fit the top cam cover and stud nuts under the top frame member.
I straddled the frame and since it is on the ground my feet were flat and easy to move the lump about with a hand each side.
Bottom mounting bolts in...I was expecting this bit to be difficult as the mounting ears had Powder Coating on them but the engine slipped in okay. The only tightness was the bottom front left bolt distance piece need some persuasion.
And best of all after removing the masking tape no chips or scratches.
... now to build the wheels. First time I have done this . should be interesting
Cheers
Gary
Auckland
On the bench
On the floor
Cheers
Gary
Auckland
