Scootman
So I just got around to firing up this 350 I just rebuilt and have an oil leak...yeah it sucks but I guess **** happens..
anyway, the right side cam bearing cover gasket seems to be leaking to me...its a pretty good drip and I'm not exactly sure where else it could be coming from... I attached a few pics, they aren't that clear but was wondering what you all thought.
Anyway, if its that cam cover gasket what would be the procedure to repair it?
I'm thinking i should "basically" be able to remove the cam chain tensioner, loosen the rockers to the - on the outer edges and remove that cover without disturbing anything else.. but not entirely sure so i figured id ask
what are you guys thinking the procedure would be to replace that?
thanks
thanks
