GaryJames
Have progressed quite quickly in getting the transmission and lower crank case assembled.
I have two questions please.:
1. When fitting the small rubber ball in the lower case I found it was a reasonable firm fit. I had though that it acted like a loose valve moving within the confines of its home in the casing with oil flow.
The one that came out during disassembly was not perfectly round and had 2 x flat areas on it and fell out on its own.
I bought the new ball on ebay specifically for the CB350 K4.
2. I have my new oversize by 1mm pistons ready to go the engineering shop with the barrels but I cant find any reference as to what clearance the engineer should bore to. Neither my Haynes manual or the CB250/350 FSM lists the clearance.
Plenty about the size of the piston but nothing showing bore measurements, even for standard pistons.
I had intended to just do the math between bore and piston size so I could advise the engineer. Page 41 ( pdf page) or actual page 30 of the FSM denotes.
I am told that Honda engines run closer tolerances so I want to get this right.
Cheers
Gary
Auckland
NZ
Cheers
Gary
Auckland
NZ
