Results 1 to 5 of 5
Thread: 78 CB400 TWIN
  1. #1
    Junior Member
    Join Date
    12.01.21
    Halifax, Nova Scotia, Canada
    Posts
    27
    Thanks Thanks Given
    5
    Thanks Thanks Received
    6
    Thanked in
    78 CB400 TWIN
    Hi all I grabbed this one yesterday for son's upgrade from 83CM250C. Less than 5000Km on the meter, perfect tool kit and manual. Mufflers have rotted inside; the left one is probably not serviceable or repairable. Four owners, decades of barn storage on an ocean coast. Tank will be fine. We'll probably want to keep this one as original as feasibly possible. The large exhaust expansion chamber between headers and mufflers appears intact. What are guys doing for muffler replacements in this situation; what years are same or nearly same for "bolt-on"? eBay stuff is pricey to ship here to Atlantic Canada. If many models are interchangeable including later in this range I'm hoping to possibly find good used replacements, will also consider aftermarket if same or nearly same style.
    Attached Images Attached Images
  2. #2
    Administrator LongDistanceRider's Avatar
    Join Date
    05.22.20
    Vancouver, Washington USA
    Posts
    7,889
    Thanks Thanks Given
    1,233
    2,453
    Thanked in
    To keep original means mufflers from a 78 or 79 CB400, the slight reverse cone shape isn't present on later models in the US. Canada got some pieces different than the US.
    Jim O'Brien
    1979 CM400T aka the Roadbike, 1978 CB400T1 semi restored, 1972 CL350K4 restoration and the 1971 SL350K1 disaster zone.
    Plus 2 SL350K0's , 2 SL350K1's, 1 CL350K0 and 1 CL350K1 waiting for space and time
    Contact: 408-239-9580 or [email protected]
  3. #3
    Senior Member Boosted's Avatar
    Join Date
    06.06.21
    Corvette Motherland, USoA
    Posts
    167
    Thanks Thanks Given
    91
    31
    Thanked in
    I looked at websites eBay, J&P Cycles, David Silver Spares, CMSNL, Partzilla, and 4into1.
    I searched eBay three different ways :
    once with "1978 Honda CB400 exhaust muffler"
    once with "Honda 18430-413-003" and
    once with "Honda 18430-413-013"
    also putting a check in the checkbox for eBay to also search descriptions along with listing titles
    It appears the mufflers on your '78 CB400 are only compatible with '78 and '79 mufflers like "L.D.R."-Jim mentioned above.
    There is 1 used left-side muffler on eBay in California that looks pitted and worse than the muffler on your '78 showing in your photo above.
    There is also 1 new (NewOldStock) left-side muffler on eBay in England that I will send you the link to privately.
    J&P Cycles shows to have 2 styles of new EMGO (aftermarket) mufflers on their website.
    David Silver Spares and CMSNL appear to have zero in stock but both will take your contact info for future IF they acquire any.
    CMSNL has in stock new aftermarket sets of head pipes if that is what you meant instead of tailpipe mufflers.
    The aftermarket exhaust manufacturers that I know of are:
    MAC, Delkovic, EMGO, Vance & Hines, Kerker, Bassani, and Yoshimura
    Another option would be to cut out the rotten rusted section of yours and weld in new metal and maybe then have the repaired pipe or muffler re-chromed or if the rot section is small enough, maybe wrap it closed with special exhaust pipe wrap.
    I've also seen a BringATrailer Honda seller in Wisconsin has who sold several used '70s/'80s Honda bikes with "repaired" mufflers that may be worth contacting to learn how they repaired their rust-rotted mufflers on bikes they've sold or serviced.
    Check your private messages here for the link to the NOS muffler in England that I am going to send now.
  4. #4
    Junior Member
    Join Date
    09.10.22
    Kansas City, USA
    Posts
    4
    Thanks Thanks Given
    2
    0
    Thanked in
    Boosted is doing the Lord's work there with his mega-reply! I will say that I've been eye-balling the mufflers from David Silver Spares for some time now and they do go in and out of stock (seen it for a few cycles now); they'll eventually be back in stock.
    78 CB400TII
    79 CB400TI x2
  5. #5
    Junior Member
    Join Date
    12.01.21
    Posts
    27
    Thanks Thanks Given
    5
    6
    Thanked in
    thanks guys
    Thanks for all the help, well beyond the call of duty! This bike will be on the lift much of the long winter here. I have been considering the possibility of salvaging these mufflers as the chrome looks so good and I have a "fab friend" that can weld and braze. This bike was a good score, quite a daytrip in distance and you can tell my son is on board with it! He expressway commuted a summer job with the CM250C so next year he'll be able to hold his lane better with the 400. 4972km on the meter!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
