Ribrickulous
Per title - seeing a turn signal flicker when I’m around 4-5,000 rpm and above.
I can see it in the turn signals themselves as well as the tach indicator.
LED turn signals and indicator. Appropriate flasher relay and diode (I think it’s from 4into1, been on the bike awhile).
Whole Rick’s setup - reg/Rec, stator, and rotor.
Checked the voltage and it’s steadily at 14.3-14.35V above 4,000. Lowest I saw it at was about 13.2V but the battery was fresh off the battery charger.
Anyone know if the flasher relay is just bad or is the high-ish voltage not going to work with any relay?
Issue has only showed up in this most recent build with the high output electric.
