Biggles
Can anyone give me the dimensions, length and diameter of the main jet needle on a CA95. Also what metric sized tires have anyone installed on CA77s.
Finally figured out where to put my intro. Thanks so much for info and clarification on carb model. It is indeed a PW20 and I am a bit embarrassed that I did not designate that in the original post. What are you on in your picture?
You might take a look at Heidenau tires, their vintage tires are inch and metric.Thanks for the conversion formula. Quite handy. I am interested though in what, if anything, anyone has actually installed on the rear of CA77 that clears everything. At one time a went up to a larger rear on my Super Hawk, noting it would clear the fender but when dropping off the center stand found it was too wide to fit between the stands legs. Doh! Looking at the 80/90s and 90/90s available today I'm beginning to understand why I've seen so many CAs with knobby or trials tires. Thanks again
