Results 1 to 29 of 29
Thread: Adjusting the valves DOES make a difference!
  1. #1
    Junior Member
    Join Date
    10.14.22
    Sierra Vista, AZ, USA
    Posts
    6
    Thanks Thanks Given
    0
    Thanks Thanks Received
    4
    Thanked in
    So there I was like so many others, I had just cleaned and re-installed the stock carbs back on my bike. 1978 CB400a Hondamatic. All stock including air box. : )
    I couldn't for the life of me get this thing to run good if at all. Kick after kick and also used the starter, and if it did start it ran badly and not for long. I adjusted the pilot screw and idle, checked and rechecked fuel, spark, etc and no bueno as far as starting and continuing to run.
    Finally I took the advice that I had read and seen on yt so many times before and decided to look at other items on the bike. I started with valve clearance. I was convinced
    that "the valves aren't going to matter that much" as I manipulated the feeler gauge, adjusted the screw and locked it all down. But I'm also open minded enuf to try. The next day I through on the tank, pulled the choke and gave the bike a kick. I was sure it wouldn't start......wrong. It started on the first kick and ran, pretty darn good. I left the choke on until I thought the bike was warm enuf to release the choke and wala, the bike still ran. I reved it a number of times and the bike still ran. In fact it ran so good that I took it out on the driveway, shifted it to 1 and rode across the driveway. By the way, the bike was still running. Holy Sh#$% and [email protected]#$, the valves do matter.
    I had never paid much attention to valves. I'm owned at least 15 or so bikes in my life and never adjusted the valves on any of them. I somehow believed that they wouldn't matter that much and always dismissed that part of service. I'm here to tell you that today was living proof that the valves do in fact matter and I'm now a very big believer in making sure that I check them from now on.
    Attached Images Attached Images
    1978 Hondamatic CB400a
  2. #2
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Moved to Tips and Tricks section.
    Glad things worked out well. Yes, these engines are sensitive to many things in order to perform at their peak.
  3. #3
    Super Moderator J-T's Avatar
    Join Date
    05.22.20
    Tea, SD, USA
    Posts
    1,746
    Thanks Thanks Given
    87
    424
    Thanked in
    It's sometimes surprising how the same symptoms can have a variety of causes. It usually pays to make sure everything is up to snuff.
    1981 CM400T
  4. #4
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Quote Originally Posted by J-T View Post
    Well said J-T, it's kinda like "90% of carb problems are electrical"... or is it the other way around??
  5. #5
    Senior Member HerrDeacon's Avatar
    Join Date
    06.01.20
    Canada
    Posts
    394
    Thanks Thanks Given
    31
    123
    Thanked in
    I've always been surprised at how many bike owners neglect valves, it was always something I've felt was vitally important and will check them on their recommended schedule. Or if its a 'new-to-me' bike, its one of the things I'll check as part of giving the bike a once-over. I wouldn't be able to rest not knowing if they were set correctly or not. At least on these old bikes its super easy to check and adjust them, my Africa Twin is a royal pain to check.
    Glad you did it and the results speak for themselves. Well done!
    Perry
    '72 CB350 / '78 XL250s / '17 Africa Twin
  6. #6
    Junior Member
    Join Date
    10.14.22
    Posts
    6
    Thanks Thanks Given
    0
    4
    Thanked in
    The difference in how well it ran was amazing. I'll never overlook valves again.
  7. #7
    Senior Member mike in idaho's Avatar
    Join Date
    06.17.20
    Orofino Idaho USA
    Posts
    994
    Thanks Thanks Given
    1
    330
    Thanked in
    Back in My shop days, when doing the 500 mile check up on a customer's new bike, it wasn't uncommon to find one or more tight valves that needed re-adjusted.
    '66 CL160
    '66 CB160
    '67 CL77
    '79 XS650
    '69 T100R
    '68 TR6R
    '69 T120R
    '72 750 Commando
  8. #8
    Senior Member Windmill John's Avatar
    Join Date
    06.04.22
    East Sussex, England
    Posts
    262
    Thanks Thanks Given
    21
    45
    Thanked in
    M640, When I read that line: “I'm owned at least 15 or so bikes in my life and never adjusted the valves on any of them.”
    It was like watching a horror film!……
    But, still, it’s good of you to admit it.
    Dude, my 1968 Honda CB250
    Tweety Pie, my 2004 BMW F650GS
    South coast of England
    www.kittos.co.uk
  9. #9
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    And of course they could have been bikes with shims, or like some of the Honda's 4 cylinders in the '80s, hydraulic "lifters" if that's the right terminology (never touched one myself). But otherwise... yeah, could end up a horror story.
  10. #10
    Join Date
    06.04.22
    Posts
    262
    Thanks Thanks Given
    21
    45
    Thanked in
    It’s a good point. I checked the shims on my 650 two years ago. Inlets close to limit, but being shims, it’ll be a while yet before they’re out.
    and, if he’s had 15 bikes with shims…..
    Or a new bike that gets sold every two to three years….
    www.kittos.co.uk
  11. #11
    Senior Member ballbearian's Avatar
    Join Date
    11.21.21
    Hagerstown MD USA
    Posts
    2,458
    Thanks Thanks Given
    1,608
    862
    Thanked in
    Quote Originally Posted by mike in idaho View Post
    I'm sure some shops figured they could skate on thorough set ups, since valves are kind of "hidden" adjustments and tight is quiet, also if it gets ridden much it will get done at the check ups (and another retail opportunity to sell accessories, etc.)I saw this a bunch in the bicycle shops I worked.
  12. #12
    Join Date
    06.17.20
    Orofino Idaho USA
    Posts
    994
    Thanks Thanks Given
    1
    330
    Thanked in
    Skate? We never sent a new one out the door without a proper check of all the settings, valve lash included. They tend to tighten up as the first few hundred miles are run up. Tight valves equal hard starting and poor idling when hot, customers don't like that.
    '66 CL160
    '66 CB160
    '67 CL77
    '79 XS650
    '69 T100R
    '68 TR6R
    '69 T120R
    '72 750 Commando
  13. #13
    Join Date
    11.21.21
    Hagerstown MD USA
    Posts
    2,458
    Thanks Thanks Given
    1,608
    862
    Thanked in
    Yeah and they burn too, right? I said "some" shops, obviously not you or your shop, you got a conscience, or you wouldn't have brought it up. I was just talking philosophies, our shop had the best rep in town but still my boss would kind of half gripe that he wouldn't see my customers the rest of the season so he could sell them more goodies.
    I've heard, "slappy valves are happy valves", is that kind of right? You got oodles more experience than me, like forever.
  14. #14
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Quote Originally Posted by ballbearian View Post
    I've always disagreed with that term and philosophy, it might be fine for the short term but too loose does damage eventually.
    The first Honda shop I worked at, where I did most of my new bike assembly prior to becoming a mechanic at the next stop, did not have us do pre-delivery checks on anything. He wanted the bikes on the showroom floor as soon as possible, they waited until their first service to get that done. Though I'm sure at least some came back with issues as a result, I never saw any of it the short time I was there.
  15. #15
    Join Date
    11.21.21
    Hagerstown MD USA
    Posts
    2,458
    Thanks Thanks Given
    1,608
    862
    Thanked in
    Quote Originally Posted by ancientdad View Post
    I remember you mentioning that the hammering effect from too loose valves could hasten the mushrooming effect on adjusters and valve stems. I suppose it's just a saying that helps me remember that they wear tighter as time goes, or that's what I was taught by an experienced friend mechanic.
  16. #16
    Senior Member RockReef's Avatar
    Join Date
    06.16.20
    Olympic Peninsula
    Posts
    760
    Thanks Thanks Given
    335
    88
    Thanked in
    Is there a tips and tricks section on this site for actually how to use feeler gauges? I’m probably on the younger side here (early 30’s, no offense), and had no clue how to use them when I started wrenching 10-15 years ago. Self taught, out of poor necessity; I didn’t have anyone teaching me much about mechanical work when I grew up.
    I taught myself with a lockable micrometer, so I could develop a “feel” for how it should feel. Because when I started the small increments really threw me.
  17. #17
    Senior Member teebo's Avatar
    Join Date
    12.04.21
    Oklahoma City
    Posts
    1,269
    Thanks Thanks Given
    173
    247
    Thanked in
    Quote Originally Posted by RockReef View Post
    Samsies. Except I'm well past early 30's.
    I did the same with a micrometer. I feel I'm a lot better now after that.
    69 CB350K1/68 CB450K0
    1969 CB350K1
    1968 CB450K0
  18. #18
    Join Date
    06.04.22
    Posts
    262
    Thanks Thanks Given
    21
    45
    Thanked in
    I always felt that dealers would definitely not check clearances on Transalps and Africa Twins. Great bikes, but it took me over five hours to to check the tappets, having to remove all the paraphernalia.
    www.kittos.co.uk
  19. #19
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    I'd be amazed if Honda didn't set the valve clearances accurately on the production line, but the dealer certainly ought to check them at first service. Bet they don't these days, engines being buried under all that extra modern junk, and if they did check them it'd be a major job to adjust them when it's shims inside cam buckets. I've done this a couple of times on my CB600, not a trivial task with 16 valves and two camshafts to remove and refit without breaking the cam carriers etc.
    I learnt to adjust valves on my C100 50cc, followed by the 175 and 250, not an issue on the other two stroke tiddlers. Good practice for my first two car engines, simple pushrod in line fours. If anything, I'm guilty of setting the clearances too tight because I can't stand tappet rattle. Loose 2 thou on the exhaust, tight 2 thou on the inlets.
    1972 CL175K7
    1998 CB600 Hornet
  20. #20
    Join Date
    11.21.21
    Hagerstown MD USA
    Posts
    2,458
    Thanks Thanks Given
    1,608
    862
    Thanked in
    Quote Originally Posted by Richard Pitman View Post
    Yikes, remove the camshafts! We had a special tool to depress the buckets when the piston was down, then a small magnet lifted the shims out for replacements. This was on FIAT's and VW Schirocco's too I guess. I'm glad my Suzi GS750L, 16 valve is not like that and has adjusters directly on the forked rockers.
  21. #21
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    Yes, shim over bucket would make life somewhat easier. I think some Kawasakis and Ducatis are like that. The CBR/CB 600 shims are tucked away inside the cam buckets, ( where they can't fly out at high rpms ) hence cam removal to get the buckets out, then messing around with a magnet to get the shim out of the bucket, a right palaver. Get the cam timing right on both cams, then torque down the cam carriers, even slight variations there alters the valve clearances. A job that I doubt I'll be bothering to do again in this lifetime ...
    1972 CL175K7
    1998 CB600 Hornet
  22. #22
    Join Date
    11.21.21
    Hagerstown MD USA
    Posts
    2,458
    Thanks Thanks Given
    1,608
    862
    Thanked in
    Wow, Richard, what an ordeal. Hats off to you for doing it once.
  23. #23
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    As Richard mentioned, some had/have shims on top of the buckets and others beneath. My CBXs had shims on top and though I never did them personally, my longtime friend still working for the Honda dealership when I rebuilt my first CBX (due to wearing out the #5 rod bearing) did the shims for me at the dealership during his lunch hour. I took the engine to him in the back of my '66 Ford station wagon and he did them right on the tailgate, swapping in one for one right out of the parts boxes with zero cost for the shims. I did the Kawasakis while at the City garage with a little ball-ended tool Kawasaki sold (and I still have the damn thing) to depress the buckets as ballbearian described above. Glad I never encountered any of the buckets with shims underneath like Richard's Hornet.
  24. #24
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    There is a Tips and Tricks section, surprised you hadn't seen it yet. I don't think anyone has done a thread on feeler gauge usage though
  25. #25
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    You can just about make out the cam lobe sitting on top of the bucket in this picture, stripped down this far just to check the clearances. The cam carriers are the most fragile looking castings you can imagine, and have to have the bolts loosened and tightened very carefully, otherwise pressure of valve springs might be enough to snap them if bolts not done in sequence, like a cylinder head.
    1972 CL175K7
    1998 CB600 Hornet
  26. #26
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Ah, the price of high-performance design.
  27. #27
    Senior Member
    Join Date
    07.01.22
    middle TN
    Posts
    101
    Thanks Thanks Given
    11
    31
    Thanked in
    Glad this turned out well. I'm no expert with feeler gauges but understand the concept. A few months ago I figured my Coleman minibike was just maybe past its 10-hr mark, where the first valve adjustment is due.
    It's got one of the Honda GX200 clones. Someone online said, "These get a little loose when hot, so adjust them a little on the closer end of the range." I did that, and deleted all the compression ... the pull cord nearly flew out of hand it pulled so easily. And of course would not start. I set them again -- to the middle number -- and it was fine. Yeah, just a little adjustment makes a big difference!
    1982 CM200T; Honda calls this pre-Rebel series "Twinstar"
  28. #28
    Senior Member
    Join Date
    02.15.21
    Oakland, CA, USA
    Posts
    539
    Thanks Thanks Given
    419
    227
    Thanked in
    I've only done valve adjustments on a couple of things. The CB450 has those eccentric adjustment shafts so it was pretty straight-forward. On my Miata I was able to loosen the camshaft bearing caps enough to get the old shims out and the new in without any serious problems. On my daughter's Toyota Tacoma I had to use the Kawasaki ball end lever to pry down the cap and get to the shim, and then blast compressed air into the notch to get the shim to finally pop out. It's definitely a fussy job and deep research into internet forums pays off.
    Bob
    1967 CB450K0 Black Bomber project, lots of scooter experience.
  29. #29
    Junior Member
    Join Date
    10.14.22
    Posts
    6
    Thanks Thanks Given
    0
    4
    Thanked in
    Lol, the thing is if it was running good I didn't mess with it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
