Results 1 to 5 of 5
Thread: Home made Honda CB350 Motorcycle Engine Test Stand You Tube
  1. #1
    Senior Member ausman1000's Avatar
    Join Date
    01.13.22
    SoCal
    Posts
    821
    Thanks Thanks Given
    317
    Thanks Thanks Received
    227
    Thanked in
  2. #2
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Interesting... sure hope he had already run that engine earlier than he showed in the video, or that was one horrendously bad warmup
  3. #3
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    Basically what I'm planning to do, when I get around to it. Except that I'm going to cheat and use a spare 175 frame as the basis for my stand, saves an awful lot of fabrication.
    1972 CL175K7
    1998 CB600 Hornet
  4. #4
    Senior Member mike in idaho's Avatar
    Join Date
    06.17.20
    Orofino Idaho USA
    Posts
    993
    Thanks Thanks Given
    1
    330
    Thanked in
    I don't think I would bother, it takes roughly the same time to stuff the engine in the frame as it would to mount it on an engine stand. Either way, you still have to connect carbs, exhaust and electrical to run the engine, I'm just lazy enough I don't want to do it twice. Also, there's no room left in My shop any more to store something I might only use once or twice.
    '66 CL160
    '66 CB160
    '67 CL77
    '79 XS650
    '69 T100R
    '68 TR6R
    '69 T120R
    '72 750 Commando
  5. #5
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    I just don't want to swap an engine that I know works for one that may or may not work, and I have spare carbs, exhaust pipes and silencers.
    If the test engine IS faulty, as I suspect, I can modify the frame / engine stand to be able to do a top end rebuild with the engine still bolted up.
    Also my garage is full up, this is something that I can play with in the back garden ...
    1972 CL175K7
    1998 CB600 Hornet
Posting Permissions
  • You may not post replies
  • You may not edit your posts
