Richard Pitman
Just wondered if anyone could shed light on this issue.
I have three running 175s. The first is a CB175 fitted with the original ( cleaned ) Keihin carbs. This starts easily, even using the kickstart, as of course it should. Idles nicely hot or cold, and generally runs well.
The other two engines have Chinese carbs fitted, after I gave up trying to get them to run well with the original carbs, no matter how well I thought I'd cleaned them etc. Plus leaking floats, sticking float valves, you name it. I replaced the Chinese main and idle jets with the correct sized Keihin jetting. On the CL and SL 175s, 38 pilots and 92 mains.
Both bikes are hard to start from cold, needing to be churned on the electric start multiple times until they stumble into a very low idle speed. Touching the throttle at this point kills the engine. Choke open or closed makes no effect in this hot weather. Once the engines have warmed up for a couple of minutes they respond well to the throttle and generally run well. Hot idle is raised somewhat, maybe 1800 rpm. Not much chance of starting them from cold on the kickstart, which leads me to the issue with the non starting rebuilt SL175 engine, which was also on these carbs.
In general terms, what causes poor cold starting, carburettor wise, assuming engine condition ( ignition, compression ) is otherwise OK ? I'm sure float levels are correct, float valves operating correctly etc. Needle clip position should not be relevant for cold start ?
