Maraakate
Original document by Jim O’Brien. Updated by Frank Sapone.
If all these tests are good then the CDI is at fault. Before replacing a CDI all these components have to test good.
Use a Multi-Meter, VOM or Volt-Ohm-Meter, with a new battery and set it to measure electrical resistance in Ohms.
Separate the three connectors from the stator to the CDI for the stator tests, use the stator side connections.
The fuel tank has to be removed to test the coil and run/kill switch. The Black w/White wire pigtail is at the CDI.
IF THE TESTS COME UP GOOD PLEASE POST A THREAD SO WE CAN VERIFY THAT YOU HAVE DONE THIS TEST CORRECTLY. WE DO NOT WANT YOU BUYING RANDOM PARTS IN A DESPERATE ATTEMPT TO FIX THE ISSUE AS IT CAN GET REAL EXPENSIVE, REAL QUICK!
Coil Test:
• Primary Side: Measure the resistance between the Yellow and Green wires. The Yellow and Green wires being measured will be coming out of the spark plug coil. The resistance should be less than 1 Ohm. Spec is 0.35 to 0.55 Ohms.
• Secondary Side: Measure the resistance of the spark plug wires with the plug end caps removed, they unscrew. Insert a probe into each wire. Spec is 7.2K Ohms to 8.8K Ohms for the stock Honda coil, other coils will have different specs.
• Plug End Caps: Measure the resistance of the plug end caps. Spec is 5K Ohms. Replacement part number is NGK XD05F.
IF THE PRIMARY OR SECONDARY IS OPEN THIS MEANS THE IGNITION COIL IS BAD, GET A USED ONE, DO THE GM COIL MOD, OR DYNATEK DC11-2 DO NOT BUY THE $20 EBAY COILS THEY ARE WRONG. ANY COIL OVER 1.0 OHM ON THE PRIMARY WILL CAUSE INCORRECT PILOT MIXTURE AND WILL CUT OUT SPARK AFTER 10 MINUTES OF RIDING. IF PLUG END CAPS READ INFINITY OR THEY ARE NOT CLOSE TO 5K OHMS THE CAPS ARE BAD, GET A NEW NGK XD05F CAP OR AFTERMARKET EQUIVALENT.
Stator Tests:
The connectors used are found under the left side cover.
• Measure the resistance of the Pink and Green wires in the large 6 pin connector. This is the advance pickup coil. The resistance should be between 10 to 30 Ohms.
• Measure the resistance of the White and Blue wires in the 2 pin connector. This is the power to the CDI. The resistance should be between 4 to 7 Ohms.
• Measure the resistance of the White wire in the 2 pin connector and Green wire in the large 6 pin connector. The resistance should be between 200 to 500 Ohms.
• Measure the resistance of the Brown and Orange wires in the large 6 pin connector. This is the primary pickup coil. The resistance should be between 100 to 200 Ohms.
The stator ohm readings listed can exceed the old spec by no more than 1 Ohm, more than that will have a negative effect on the timing advance. If unsure after measurement, you should verify with a timing light. At idle in Neutral the timing marks should align to the ‘FN’ mark. In 1 or 2 the timing marks should align to the ‘F’ mark. Around ~4000 RPM the timing marks should align somewhere between the double line ‘| |’ marks.
IF ANY OF THE ABOVE MEASUREMENTS READ INFINITY THIS MEANS A WINDING IS OPEN AND THE STATOR NEEDS REPLACED OR REWOUND! CONTACT KIRK AT CUSTOM REWIND IN ALABAMA TO GET IT REWOUND, 1-205-798-7282
Change Relay Test:
Set your DVM to Volts. Connect the red probe to the Green w/ Red tracer in the 2 pin connector. Connect the black probe to the Green wire in the 3 pin connector. Put the bike on the centerstand and place the bike in Neutral. Turn the key to the “Run” position.
• In Neutral the voltage should be about 0.7V for OEM. It will be much lower than this if you built one with a MOSFET or have ordered one from me.
• In 1 and 2 the voltage should be 11-13V (should be the same as your battery voltage).
IF YOU ARE UNSURE IF THE CHANGE RELAY IS DEFECTIVE SIMPLY DISCONNECT THE GREEN W/ BLACK AND GREEN W/ WHITE BULLET CONNECTORS COMING FROM THE SIDESTAND SWITCH. IF IT NOW SPARKS THIS MEAN THE SIDESTAND SWITCH IS DEFECTIVE. ADDITIONALLY YOU CAN DISCONNECT THE TWO TERMINAL CONNECTORS LEADING TO THE CHANGE RELAY FROM THE NEUTRAL SWITCH. THE STARTER WILL NOT WORK, BUT YOU CAN USE THE KICKSTARTER TO STILL VERIFY A SPARK. IF IT NOW SPARKS THERE IS SOMETHING WRONG WITH THE CHANGE RELAY.
Run/Kill and Ignition switch Tests:
Connect one probe to the Black w/White tracer pigtail wire coming out of the main wiring harness that connects to the CDI unit. Connect the other probe to the negative battery terminal. The results should be:
• Ignition switch on, Run/Kill switch in Run position: Infinite Ohms reading meaning an open circuit.
• Ignition switch on, Run/Kill switch in Off position: 0 Ohms or close to that showing the circuit is closed/completed to ground.
• Ignition switch OFF, Run/Kill in any position: 0 Ohms or close to that showing the circuit is closed/completed to ground.
IF YOU ARE UNSURE IF THE IGNITION SWITCH OR KILL SWITCH IS DEFECTIVE SIMPLY DISCONNECT THE BLACK W/ WHITE TRACER BULLET CONNECTOR LEADING TO THE CDI. IF IT STARTS THERE IS SOMETHING UP WITH THIS SWITCH
Alternator Tests:
Use the connector with 3 Yellow wires.
• Select/connect to one Yellow wire with a probe. Connect the other probe to one of the remaining 2 Yellow wires, resistance should be below 1 Ohm.
• Repeat twice using a different wire each time.
• If the readings are good then test each of the Yellow wires with one probe connected to ground. There should be an Infinite Ohms reading meaning none of the charging coils is shorted to ground.
Stator Crank and Running Tests with PEAK VOLTAGE ADAPTER (Recommended)
• Connect one probe to Green on the 6 pin connector and the other to White on the 2-pin connector. With kill switch OFF crank the bike. It should read about 14 Volts.
• Connect one probe to Green on the 6 pin connector and the other to Blue on the 2-pin connector. With kill switch OFF crank the bike. It should read about 1.2 Volts.
• Connect one probe to Orange and the other to Brown on the 6-pin connector. With kill switch OFF crank the bike. It should read about 2.0 Volts. This is the pickup sensor.
• Connect one probe to Orange and the other to Brown on the 6-pin connector. Start the engine. At idle it should read about 2.5 Volts, it should progressively reach about 2.9 Volts as you give it more throttle. This is the pickup sensor.
• Connect one probe to Green on the 6-pin connector and the other to White on the 2-pin connector. Start the engine. At idle it should read about 219 Volts, it should progressively reach about 300 Volts as you give it more throttle. This is the low RPM coil.
• Connect one probe to Green on the 6-pin connector and the other to Blue on the 2-pin connector. Start the engine. At idle it should read about 232 Volts, it should progressively reach about 240 Volts as you give it more throttle. This is the high RPM coil.
• Connect one probe to Green and the other to Pink on the 6-pin connector. Start the engine. At idle it should read about 1.4 Volts, it should progressively reach about 5 Volts as you give it more throttle. This is the advancer coil.
• Connect one probe to Green and the other to Yellow on the 2-pin on the CDI/coil connector under the tank. Crank or start the engine. It should read about 0.79v. This tests the output of the capacitor in the CDI.
Stator Crank and Running Tests with ANALOG VOLT METER
• Set your AVM to 10VAC range and connect one probe to Green on the 6 pin connector and the other to White on the 2-pin connector. With kill switch OFF crank the bike. It should read about 2 Volts.
• Connect one probe to Green on the 6 pin connector and the other to Blue on the 2-pin connector. With kill switch OFF crank the bike. It should read about 1.5 Volts.
• Set your AVM to 10VAC range and connect one probe to Orange and the other to Brown on the 6-pin connector. Start the engine. At idle it should read about 0.1 Volts, it should progressively reach about 1 V as you give it more throttle. This is the pickup sensor.
• Set your AVM to 250VAC range and connect one probe to Green on the 6-pin connector and the other to White on the 2-pin connector. Start the engine. At idle it should read about 60 Volts, it should progressively reach about 75 Volts as you give it more throttle. This is the low RPM coil.
• Connect one probe to Green on the 6-pin connector and the other to Blue on the 2-pin connector. Start the engine. At idle it should read about 100 Volts, it should progressively reach about 150 to 200 Volts as you give it more throttle. This is the high RPM coil.
CDI Test
There is now a test that can work with digital or analog meters. Please refer to this thread to test it.
If you're still having problems, post here and we can help you go through the tests. I also have a test kit available that I can ship at your expense with a core charge. See the following thread for details: Hondamatic CB400A/CM400A/CM450A Community Ignition Test Kit!.
Rotor Test
Remove the rotor and check that the magnets on the inside grab a small flat head or pick tool. They should grab it with some good force. Conversely, check the "button" magnet on the outside of the rotor. It should also forcefully grab the tool. If it doesn't then the rotor is bad.
Coil Test:
Stator Tests:
Change Relay Test:
Alternator Tests:
CDI Test
Rotor Test
