Herb400t
I'm replacing old wiring connectors and repositioning some elements of wiring harness and have this question: there is a bundle of 6 wires running between the CDI and stator but they use two connectors, one four pin and one two pin. I'm wondering if it's okay to just replace with one 6 pin connector? OR, if for some reason the blue and white wires need to be separated from other four, as an alternative, could i then use an 8 pin connector and leave a two-pin space between? I'm guessing since wires are coming from CDI, testing some aspect of it's function might be reason for wires being separated?
