Troy
I'm sure with enough enough time I would eventually solve this but maybe somebody here can point me in the right direction.
CD175, 6 Volt.
Bike had no functioning bulbs when I bought it so I can't confirm functional wiring but I tidied up the original wiring harness, new connectors where needed, new loom as needed. Thought things were wired back up pretty good and true to the wiring diagram.
New LED bulbs throughout, new battery. New R/R, winker relay, etc.
Tested signal lights and they work great. Plug in the headlight bulb and it works but the signals stop working. Unplug the headlight and the signals work again.
I assume I am looking for a short or a ground issue but not sure which and not sure which circuit, headlight or signals? Any thoughts on a good starting point?
Cheers
CD175, 6 Volt.
Cheers
