Results 1 to 5 of 5
Thread: Piston ring gap spacing guide
  1. #1
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    Thanks Thanks Received
    4,707
    Thanked in
    When re-assembling the top end of the engine, piston rings should have their end gaps spaced around the 360° of the piston to minimize blow-by.
  2. #2
    Join Date
    05.22.20
    Vancouver, Washington USA
    Posts
    8,575
    Thanks Thanks Given
    1,500
    2,745
    Thanked in
    I will add that the top 2 ring gaps should be on the intake side of the piston, not on the thrust side.
    Jim O'Brien
  3. #3
    Super Moderator J-T's Avatar
    Join Date
    05.22.20
    Tea, SD, USA
    Posts
    1,745
    Thanks Thanks Given
    87
    424
    Thanked in
    I was taught long ago that the gaps on the top compression ring and the second compression ring should be 180 degrees apart. This forces the gasses to travel the longest distance to get from one ring gap to the next. One piece oil rings gap was then aligned slightly off the top compression ring. Same reason. Three piece oil rings had the top ring near the top compression ring, the bottom ring near the second compression ring. Again, all this was designed to force the gasses to travel the maximum distance to get from each ring gap to the next.
    1981 CM400T
  4. #4
    Senior Member
    Join Date
    05.31.20
    Calgary, Alberta, Canada
    Posts
    551
    Thanks Thanks Given
    4
    269
    Thanked in
    And after assembly they do their own dance.
    https://www.highpowermedia.com/Archi...f-piston-rings
  5. #5
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Interesting study, not something I was aware of.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
