Results 1 to 7 of 7
Thread: Broken chain guard post repair
  1. #1
    Senior Member CB2NR's Avatar
    Join Date
    06.18.20
    Lawton, Michigan USA
    Posts
    249
    Thanks Thanks Given
    22
    Thanks Thanks Received
    84
    Thanked in
    Received a CB175 case which had a broken post. Mostly likely happened when the chain was too loose or let go. I’ve also seen this break when the case is accidentally dropped.
    First the case was machined smooth. Measurements were taken, and a new post made. I chose to thread the post into the case via a 6mm x 1.0 stud. The stud is sealed with red Loctite, and threaded firmly into place. Welding the post is another option.
    Save thoses cases
    Photo after repair.
    Attached Images Attached Images
    -Ray
  2. #2
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Very nice repair. Even though the work is fairly obvious, a few pics of the steps along the way for the lesser-knowledgeable among us would be great if you have them.
  3. #3
    Join Date
    05.22.20
    Vancouver, Washington USA
    Posts
    8,575
    Thanks Thanks Given
    1,500
    2,745
    Thanked in
    Good idea and execution.
    Jim O'Brien
  4. #4
    Join Date
    06.18.20
    Posts
    249
    Thanks Thanks Given
    22
    84
    Thanked in
    Quote Originally Posted by ancientdad View Post
    Thanks guys.
    Could only find two other photos. The first show the machined spot, the other with case half held in place.
    Once the area was cleaned up, the chain guard cover was installed, and an appropriately sized center punch was used to locate where the threaded stud would be installed. The other measurement was taken to know how long to make the new piece. Both ends of the new piece was drilled & threaded to 6mm x 1.0.
    -Ray
  5. #5
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,886
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Thanks for adding them. Not everyone will have the tools to work with that you do, but the plan will still work the same way.
  6. #6
    Senior Member
    Join Date
    06.01.20
    Worcester, England
    Posts
    1,752
    Thanks Thanks Given
    134
    547
    Thanked in
    I made a much less elegant repair using a piece of aluminium bar and JB Weld. Against all odds, this repair has lasted several years.
    Bar cut exactly to length, drilled and tapped to take sprocket cover screw. By attaching it to outer cover, this ensured exact alignment by using the other two screws to attach cover to case whilst JB Weld cured.
    1972 CL175K7
    1998 CB600 Hornet
  7. #7
    Join Date
    06.18.20
    Posts
    249
    Thanks Thanks Given
    22
    84
    Thanked in
    Nice work, Richard. Always good to have options.
    -Ray
Posting Permissions
  • You may not post replies
  • You may not edit your posts
