I have taken the carbs apart to check on the interior condition and it looks like the jets for sure are aftermarket and larger than stock sizing. The needle has a D2 code on the upper top section, so it could be OEM. The float valve and other air or fuel mixture screws are suspect too.
I will Ultrasonic clean the bodies further beyond the the initial soak in my go to carb cleaner "AWESOME" I kid you not.
About 3-4 oz in a heated tank of 6 L of water does wonders, better than any other "Simple Green or Pine sol" cleaning with less chance of the carb body discolouration from the chemicals used.
So I will be asking for input on these as I have done a early CL175 set of carbs and the design is similar between the two sets. Yet any known issues and fixes for modern gas or jetting experience will be very helpful. I am an experienced Honda carb rebuilder of many years, yet always open to more knowledgeable people on new bikes.
Here are the pics of the jets with top left #42 Slo jet and top right main jet at #135 and the float valve noted as a 2.0 size. There is no stylized "K" on the jets, so aftermarket, unless someone else has a better understanding of the jet information.
