I am sure a lot of us have a small ultrasonic for carbs etc, but for those unaware - evaporust is A LOT more effective if you use it in a heated ultrasonic cleaner. I use small plastic containers inside the tank so the evaporust lasts longer, but from what I have seen, it never seems to wear out. I strain it through a coffee filter to remove the grit and keep reusing. Below is a picture of the results after 20 minutes in a sonic bath of evaporust at around 155°F. I should add this was with no mechanical cleaning or wire brushes.
Lee
