Who's up for a complex wiring question? I totally understand if you're not, it is the holidays, after all.
My bike is a bit of a frankenstein but essentially it's a CB450 K0 Bomber. It has a bomber loom and all the lights and instruments are Bomber too. Only thing is, I have a K1 ignition switch. Reason is, I can't afford a K0 one and I have a nice condition K1 switch which is already on there, with keys. I've been wiring everything up for a while and mostly things are working well, but I can't get all my lights on at the same time. In key position one the ignition, headlight work but taillight does not. In position 2 taillight works but ignition and headlight do not. I would like to have all the lights and ignition working on a key position and, if possible, just ignition working on the other key position (so I don't need an extra light switch). I have never been able to get the neutral light working but all other instrument lights do work. Currently the Brown/White wire from the ignition switch is not connected to anything. I have a hunch that this might be the sticking point but not sure where to connect.? If anyone has any idea I would be grateful and impressed. Thanks and Happy Christmas, Hawksmoor
