TomF
I have a 1963 CB77 which will require an engine rebuild as the previous owner partially took it apart and I can’t be sure all the parts are there until I break back into it. Are the CB and CL engines the same, and are there major changes between the years the CB and CL were manufactured that I need to be aware of? I ask this because I found an inexpensive “donor” engine I could buy and use for parts, not sure of the year of the engine or if it is from a CB or CL. If I don’t buy the engine I’m sure I will buying replacement parts.
Just beginning some research before I get too deep into this project. This is the first CB77 I will have worked on.
