Idle air screw driver. .jpgAs others have observed getting into the space under the carbs to adjust the idle air screw can be a challenge. There does not seem to be any commercially made screwdriver small enough to fit. At discovering this for myself I decided to make what I needed. The bit is a small slot screw driver with a six sided shank designed to be used in a drill or impact driver. The nut is one I had in my nuts and bolts collection as it happened it is a nut with a cast in washer, which turned out to be helpful as I will explain in a moment.
As found the bit would not fit into the threaded hole but I figured that with some judicious hammer work I could make it fit. Drove it in by placing the nut washer side down on my vice set such that the bit would go through the hole starting with the blade. Once I had it driven through enough I cut off the remaining shank with a cut off wheel.
I tried it out and it works a treat but I had no real sense of how far I was turning the screw so this is where the built in washer on the nut became important. In order to get the necessary tactile feedback I filed the round washer into a four sided square with slightly rounded corners. Now I can tell when I have turned it every quarter turn.
I now have a custom made motorcycle tool in my bike tool kit at a cost of Zero dollars Cdn (US dollars at par - with no penalty in this case)
