Results 1 to 5 of 5
Thread: Ride-On Motorcycle tire balancer and sealant.
  1. #1
    Senior Member ALBeix's Avatar
    Join Date
    09.06.21
    Kaslo, BC, Canada
    Posts
    169
    Thanks Thanks Given
    10
    Thanks Thanks Received
    57
    Thanked in
    I did a search for "Ride-On" on the entire forum and came up empty so thought I would put this out there to make members aware of it.
    Ride-on is a waterbased viscous product that does a superb job of balancing and (I assume) flat proofing. I say assume since I have had no flats with Ride-On installed.
    Unlike Balance Beads Ride-on can be installed in both tires in less than 10 Minutes.
    For those that do not believe in miracles in a can you can have a look at the Ride-On web site HERE and if you still do not trust the testimonial claims on the Ride-On site do your own research. There are endless positive reviews of Ride-on on all manner of forums and facebook pages.
    The stuff works and all of my bikes run with it.
    PS - I get nothing for this endorsement beyond letting others know about a product that works and works well!
  2. #2
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Moved to Product Reviews section.
    I'm assuming the sealant aspect is intended for tubeless tires of course. For the balance aspect of it, can it be used in tube-type tires I wonder?
  3. #3
    Join Date
    09.06.21
    Kaslo, BC, Canada
    Posts
    169
    Thanks Thanks Given
    10
    57
    Thanked in
    Quote Originally Posted by ancientdad View Post
    As seen on the Ride-On web site HERE it works with both tube type and tubeless tires.
  4. #4
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,707
    Thanked in
    Quote Originally Posted by ALBeix View Post
    Thanks, I didn't go to the link.
  5. #5
    Join Date
    09.06.21
    Kaslo, BC, Canada
    Posts
    169
    Thanks Thanks Given
    10
    57
    Thanked in
    Check out the testimonials of the linked page. Some amazing stories there.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
