Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Don't overlook our Welcome Package, it contains many links to important and helpful information about functions at VHT like posting pictures and sending PMs (private messages), as well as finding the parts you need.
Looks like someone has ground on one of the shoe to possibly address a grabby brake problem. Probably didn't help, since they ground on the wrong shoe to fix the problem.
It doesn’t look like normal wear, the markings go the wrong direction. Did you find any pieces of it in the hub? Personally I would replace them, it’s highly recommended on any old (new to you) motorcycle.
The ends of the linings have been ground down, chamfered, by Honda. Those are the original brakes and need to be replaced! the glue is old and will let the lining separate from the shoe which will cause the brake/wheel to lock up.
Definitely replacing. I have new OEM rear pads, they look a lot different (and are chamfered, but only a small amount right at the end, a much steeper angle).
I’m doing tires/tubes, brakes and wheel bearings on all 4 wheels both bikes.
