Results 1 to 11 of 11
Thread: A fix for full advance timing troubles...
  1. #1
    Senior Member Middletons's Avatar
    Join Date
    06.03.20
    Roeland Park, KS.
    Posts
    221
    Thanks Thanks Given
    30
    Thanks Thanks Received
    65
    Thanked in
    I find myself having to look this thread up every few years, so I thought I'd bring it over from the other forum as it's proved very useful.
    Posted by user: Thrilou
    ...Under certain situations.
    We all know that worn advancer weight stop tabs can cause the timing to be too far advanced, but what to do when your timing is good on one side and too far advanced on the other?
    This is the question I asked HERE.
    No matter which advancer I selected, there was this discrepancy at full advance.
    I emailed Mark Paris (AKA Hondaman) and asked his advice. Below is the lengthy correspondence I had with Mr. Paris about a month ago:
    Bryan said:
    Hi Mark,
    I have one of your ignition units for my CB350 twin and we have corresponded a bit in the past.
    I am having a problem with my ignition timing unrelated to your unit. I am hoping you could shed some light on this problem or at least offer some advice to mitigate the issue.
    Here it is in a nut shell:
    When both cylinders are timed exactly dead on at idle, the left side and right side end up at two dramatically different timings at full advance.
    In more detail:
    Sometime ago I noticed signs of detonation in the right cylinder (aluminum deposits on spark plug!). When I checked the timing with a timing light, I found that at full advance, the right side was advancing past the furthest timing mark by about half of the distance of the entire advance range... well past the furthest allowable advance time. The left side only advanced to the middle of the advance range... odd.
    I suspected the advancer unit, as they are reported to wear at the advance stops causing too much full advance. I measured some other advance units I had laying around and chose the one that had the least distance between the stop tabs. I timed it statically and then timed idle dynamically. Right side is exactly in the middle of the timing marks but the left side is now a bit retarded from the first full advance mark... About the same degree of discrepancy between the right and left that the original advancer showed, just less advanced overall.
    No matter what I do (and I am setting the dynamic idle timing spot on) the timing at full advance is drastically different between the right and left.
    I reinstalled the first advancer and tried to sort of split the difference by advancing left side overall (rotating the timing plate) and the retarding the right side over all (moving points) thus resulting in full advance times that are both inside the full advance range. The problem is, the idle timings are off (advanced on the left and retarded on the right). This makes for lousy response from off idle to 3000rpm or so. It does run fine once the engine is at full advance (4000 on) which seems to make sense... The bike also stalls regularly after sitting at idle under these conditions.
    I know some people suggest setting the advance timing to where you like it and letting the idle timing be where ever it ends up, but I can't see how this is a good idea. This seems like a poor way of dealing with the problem.
    Perhaps having differently timed idles will result in different demands from the carbs... I haven't spent any real time dialing them in after changing the timing settings... perhaps this will yield better results.
    Should I try advancing or retarding the overall timing so that right and left are within the full advance letting the idle times remain the same relative to one another (albeit, a bit advanced or retarded from the ideal setting)?
    What could cause this problem? Given the design of the advancer, with identical idle timings, I can't see how I could be getting two different advance times (the points cam should be in the same position for both rubbing blocks, correct?).
    Have you ever observed anything like this before? Any advice or solutions?
    I apologize for the lengthy email... I realize you are a busy guy, so If you don't have the time right now, I completely understand.
    Thanks in advance.
    Bryan
    Hondaman said:
    This is actually pretty common (even back "in the day"), and it comes from 2 things.
    First, the thin washers at the base of the rotating cam on the advancer are often gone: they were plastic on the 1970 and later 350. These are .004" thick (0.1mm) washers that were used to shim the base of the cam flat and to make the clearance between the top bolt's washer and the end of the cam about 0.004" or so. Also, over time, the pivot area inside the cam has worn, adding extra clearance that lets it rattle back and forth. This tends to make the L cylinder late at full advance and the R cylinder follow the points plate position.
    You can test yours easily for excessive clearance at the top bolt, and shim it at either the top or bottom to take up some of the slack. The ID bore is a tougher issue, and it came from the bike sitting for a long time, getting a little rusty, then getting run, so it sanded the ID of the cam into the oval shape it has now.
    I've given some thought to making refurbished units like these for the Fours, although they did not wear as badly. It would consist of making a sleeve to fit over the shaft and fill in the wear, much like on the end of a crankshaft on a common V8 engine where the front seal leaks. It may become a project later this year? In the meantime, try the shims, making some from brass sheet that you can get at Ace Hardware in varying thicknesses.
    HM
    B said:
    Mark,
    Thanks so much for your reply.
    I removed and measured the parts that you mentioned.
    There definitely is play at the points cam top bolt as you said. .012"
    to be exact. I do have a shim that sits under the points cam. It is
    metal, however, and measures .011" I actually have three of the shims,
    all measuring the same.
    I checked the roundness of the advancer shaft OD (where the points cam
    rotates) and the points cam ID.
    Shaft OD measured .589 and cam ID measured .590 (I measured all the
    way around, top and bottom). .001 difference and no detectable
    out-of-roundness... seems like as good as it gets.
    I will make a shim measuring .008 and place it under the cam to take
    up the slack and see if this helps.
    Thanks again for your help. I truly appreciate it.
    Bryan
    HM said:
    Let me know how it turns out?
    Thanks,
    HM
    B said:
    Mark,
    Today I shimmed the points cam as you suggested. Timing at full
    advance is now spot on!
    I have to admit, I couldn't see how a few thousandths of lateral play
    could affect things so dramatically. Out of roundness (which wasn't an
    issue in my case) makes sense to me, but I was somewhat incredulous
    that this shimming would totally fix the problem.
    To be specific:
    I used a spare steel points cam shim, super glued it to the end of a
    damaged points cam (something to hold on to!), filed it down from .012
    to .007, removed the shim and cleaned it.
    with the extra shim installed, I have .004 of clearance, cold, and
    this brought the timing on the right side back from over advanced to
    the middle of the range, identical with the left (or near identical,
    as far as I can tell without a mark to line up...).
    This is a great relief!
    Thanks so much for your help.
    Would you mind if I shared this with the guys over at the Hondatwins.net forum?
    Bryan
    HM said:
    I'm glad it worked! It's been a long time since I did those, but it was a common problem because the shims on many were plastic, and broke off in use. It's the tabs where they lock into the advance weights where the looseness makes the cam tilt: the upward pressure of the points feet (90 degrees apart) cause it to tilt upward as it rotates the high side down, which shifts the timing late for the "L" points. So, when the "L" points get set up first (per Honda's instructions), the "R" points end up advanced. The shim presses the cam down into those slots on the weights and holds the alignment better.
    Can be frustrating!
    HM
    The only thing I can't figure out is the "plastic washer" thing... I've never seen a plastic washer in any parts fiche (although I suppose no parts fiche shows an exploded view of an advancer unit) or heard mention of it until now (but what the hell do I know? Certainly not as much as a man who's been working on them since they were new). Nevertheless, shimming the lateral play on the points cam solved the problem. Whether done the way I did it by filing down a spare steel shim or constructing one from scratch, since it's a quick and easy experiment, it's worth a try if you're experiencing this problem.
    Be sure to accurately check for out-of-roundness of the point-cam shaft as Mr. Paris suggests. If this type of wear exists, it seems reasonable to try and find a good used unit since repairing this kind of damage is a bit more difficult.
    I hope this is helpful to everyone. Be sure to check your timing on both sides and watch for signs of detonation!
    User Sikeclass responds:
    Came across this thread, and I'm hoping it's the answer to my problems. Might be the answer for a few others as well. Been chasing what seemed like a lean condition for years, even when dialing everything to the point of being sooty black rich. The best way I've seen it described was, "it feels like fish nibbling on the line". That's on a good day. On a bad day, it feels like blatant misfires/backfires. Never thought to compare the advances. Left was always good, at idle and advance. Right was always good at idle, and never checked the right advance until I saw this thread. It ended up being significantly past the advance marks. Totally makes sense now.
    To update the thread, I've taken a picture of advancer apart.
    The pieces are arranged in stacking order. The washer thrilhou is talking about, is the thin washer that slides on the pipe portion of the advancer body. (Sorry my terminology is all off.) It's shown, just behind the advancer body, and the removable cam part slides on top of it, and is then locked down with the washer and bolt.
    My washers were both made of very thin metal. I had a spare advancer, and noticed that one washer was much thinner than the other, to the point of being flexible. Both advancers had a bit of slop, but when I stacked the washers onto one, it removed most of the up and down movement in the cam. So this is an option if you can get your hands on another advancer. I'd already ordered some 0.004 shim stock from Amazon, before I got the bright idea to stack.
    350's and 360's
    CB350F
    CL175
  2. #2
    Senior Member
    Join Date
    12.26.20
    Edmond, Oklahoma
    Posts
    165
    Thanks Thanks Given
    14
    12
    Thanked in
    Can you send photos for the location of what area you measured and shimmed?
    thanks,
    Jetmech
  3. #3
    Join Date
    06.03.20
    Roeland Park, KS.
    Posts
    221
    Thanks Thanks Given
    30
    65
    Thanked in
    360 pictured, but it’s the same concept for all the models.
    Measure between #8 and the points cam. Apparently, the points cam itself can also wear on the inside diameter causing a sloppy fit, and instability.
    The shims are behind the points cam.
    350's and 360's
    CB350F
    CL175
  4. #4
    Senior Member
    Join Date
    12.26.20
    Edmond, Oklahoma
    Posts
    165
    Thanks Thanks Given
    14
    12
    Thanked in
    Quote Originally Posted by Middletons View Post
    never heard of such wear.
    thanks
    jetmech
  5. #5
    Member Hankus's Avatar
    Join Date
    03.02.22
    San Antonio, Texas, USA
    Posts
    32
    Thanks Thanks Given
    5
    5
    Thanked in
    I'm having a problem in visualizing this fix. Do you have photos?
    Hankus
    Hank Auderer
    San Antonio
    '72 CB350K4
    '73 CB350G
    '79 CB750 DOHC
    '80 CB750 DOHC
    '76 Goldwing
    '80 CX500
  6. #6
    Sensei 66Sprint's Avatar
    Join Date
    05.22.20
    Roanoke, Virginia
    Posts
    2,022
    Thanks Thanks Given
    17
    961
    Thanked in
    Hank.....Give me a call.....Steve
    Contact info :
    For e-mails; [email protected]
    To send donations to the cause or towards my phone bill by PayPal, please use [email protected] to identify my account....
    Please include your vintagehondatwins username so I know to whom to send a thank-you ....
    Phone: (540)-525-5199
  7. #7
    Join Date
    03.02.22
    Posts
    32
    Thanks Thanks Given
    5
    5
    Thanked in
    Quote Originally Posted by 66Sprint View Post
    Steve - thanks! I'm about to travel to Ft. Worth (I'm in San Antonio) for 10 days, and will call you when I return and have both my advance plates in front of me on the bench.
    Hank Auderer
    San Antonio
    '72 CB350K4
    '73 CB350G
    '79 CB750 DOHC
    '80 CB750 DOHC
    '76 Goldwing
    '80 CX500
  8. #8
    Senior Member Maraakate's Avatar
    Join Date
    06.07.22
    Lancaster, PA, USA
    Posts
    652
    Thanks Thanks Given
    316
    185
    Thanked in
    A little bit of devil's advocate here, but it's well known to actual career mechanics to take Mark/Hondamans advice with a huge grain of salt.
    See the following articles, two are from Mike Nixon and the other is Ken from Cycle X.
    * https://www.motorcycleproject.com/text/paris.html
    * https://www.motorcycleproject.com/text/sohc4.html
    * http://www.cyclexchange.net/Fact%20or%20Fiction.htm
    79 CM400A Hondamatic
    77 CB550K
    74 Yamaha DT250
    76 Puch Maxi E50 (Nostalgia Edition)
    81 Puch Maxi E50
    82 Puch Maxi ZA50
    Home of the Homebrew Hondamatic and CM400T CDI -- NOW AVAILABLE for plug and play CDI. Get one or a kit here.
  9. #9
    Join Date
    05.22.20
    Vancouver, Washington USA
    Posts
    8,575
    Thanks Thanks Given
    1,501
    2,745
    Thanked in
    Good articles and lots of truth in them.
    Jim O'Brien
  10. #10
    Senior Member fxray's Avatar
    Join Date
    05.01.22
    Central Illinois
    Posts
    170
    Thanks Thanks Given
    148
    115
    Thanked in
    Quote Originally Posted by Jetmech View Post
    thanks
    jetmech
    Quote Originally Posted by Hankus View Post
    Hankus
    This all rang a bell with me. I keep a notebook on each of my bikes, and I went back to see what I had written about the AAU on my CL350K3. I found these notes from 3/26/2014:
    From a thread by "delineator" on the old forum, end play should be about .004" to .005". If greater, and especially if the ID of the points cam is loose on the sleeve part of the AAU, at higher end of the RPM range the points cam can tilt on its axis and cause the RH points to advance way beyond proper range.
    I found two shim washers stacked under the legs of my points cam.
    They were .615" ID x .775" OD; one was .0045" thick, the other .0055" thick. Installed with these two shim washers, the points cam had .014" end play -- in and out.
    I removed the two existing shim washers that had combined thickness of .010" and replaced them with a single shim washer from McMaster-Carr that is .020" thick. This gave me .004" end play.
    The new shim is metric dimensioned and is made of spring steel. It is slightly larger diameter, measuring 16mm ID x 22mm OD. (In inches, that is .630" x .866"). It fits fine. Minimum order quantity is 25 pieces, and I just checked -- I still have 24 pieces left to go into my estate sale.
    https://www.mcmaster.com/98055A222
    The bike has covered right at 12,000 miles since this repair and has not blown up yet. I think I checked initially with a timing light to verify that the advance stopped properly on both cylinders, but I must admit that I have not checked it dynamically again. I check the static timing about once a year and adjust if needed. Also, I don't know if the RH side was advancing too far before I made this change. This was one of those "while I'm in there deals."
    Ray
    1970 SL350K0; 1970 CB450 K3; 1971 CL350K3
    Plus a few non-Hondas
  11. #11
    Join Date
    05.21.20
    Nature Coast, FL
    Posts
    17,887
    Thanks Thanks Given
    3,123
    4,708
    Thanked in
    Thanks Ray, good note-keeping on your bikes. I've not encountered that issue myself, but not owning a vintage twin again until 2016 is a big part of it since I've had a lot less exposure to their aging process than I did while they were a lot newer and regularly ridden. Since this subject and issue came up here at VHT I've thought about it a lot more often, and solutions like this for real life experiences with the advancer are great content for archival.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
