greenjeans
Installed an EK219H cam chain on a 72 CB450. Parts were bought (not by me) before I found this site. Anyway, I installed the chain and both timing marks on the cam were just slightly off, about 1-1.5mm each cam.
Will that make a difference when timing the motor? I set the timing with a test light first, then checked with a timing light. Left was spot on - advance as well. Right needed a little adjustment.
Is it worth worrying about? Would you advance or retard the timing to compensate?
