The compression is around 150 psi and it's time to do something about it. I know it could be the gaskets, the valves or the piston rings.
How and in what order do you think I should find out why the compression is low?
I've seen people test the valves if they leak with gas or soap water and then blow with air from behind. I have new engine gaskets but I guess once I put them on I don't want to open up the engine again or can I?
I think I will be able to fix the valves but how do I found out if I really need to buy new piston rings?
