Really?
Yeah, I can see I posted it in DOHC.
Haha, ok. I'm just a bit chocked, maybe tomorrow I'll put on my pants inside out \_(ツ)_/
Tubeless tires will work fine with tubes so no issue there
Doesn't look like Pirelli makes the MT60 in a small enough size. Stock size is 120/90/16 and for street tires you can just barely fit a 130/90/16.
Kenda K761's are an option for the rear but the narrowest front is a 110 which may not fit. If you went to a CB450SC front wheel, 19", the they do have a 100/90/19
https://powersports.kendatire.com/e...escooter/dual-sportadventure/k761-dual-sport/
A 110 is a plus 2 oversize which isn't good. It's really too wide for the rim to be safe. A 100 would be a better one to use. Just because it fits or looks good doesn't mean it's right, there's lots of pictures of build with oversized tires that look really good but in reality they are unsafe on the road. Ever notice that you never ever see those bikes in actual use?I was thinking about doing a scrambler build with my '83 and the kenda k761 were the closest I could find, previous owner put a 120 street tire up front and it skweeks by. So 110 would work on mine, so should, maybe work on a 79? I don't know.
I'm looking for on-off road tires. Any recommendations?
I'm thinking of using a Pirelli MT60 130/90 - 16 front tire as rear tire. However I'm not sure it works with tubes.
