Juneaudave
Thanks for the pictures and posts Bill! Its interesting to see what it would take to tackle one something like this.
It wasnt anything bad but it must be against your program cause it did it again.
Bill H
bilbikek411 I have a doctors appt in an hour . Will look it up and get back to you tonight.
ancientdad. PM sent.
Bill H
bilbikek411 Amazon. Vessel Impact Driver # 250001.. Sold by kt. japan. $68.41.
Bill H
Looks like the last oil change that engine had was when it was about 5 years old, yuck.
I can clean the fork up its the bearing that concerns me. There is no way to make it better and even running in oil its going to vibrate . You are right its his decision but I hate to have my name on it.
Bill H
Bill H
Same here... I would either fix it properly or return the engine parts to him as-is.......
IF you reassemble the engine knowing the crank likely will fail, you not only allow possible catastrophic damage to the bike, but a possible liability suit if he is injured/killed due to that failure........
Not worth the risk in my book.......
I talked to the owner today about 10 AM .He called me at noon and said he found the brgs. On hold for a couple of weeks but then should be good to go. He has the frame finished and painted it the Honda blue instead of black looks good. He also found new spokes and nipples, unpainted side covers, all new chrome trim and a complete set of nuts bolts and screws. I asked him about his source but didnt get an answer. I have the gasket set but the seals are not here yet. He bought one over rings and wants me file them to fit. A machine shop is doing the cylinder head and valves , the cylinder looks good and may clean up with a hone but we will check the bore. I am getting excited about the build again.
Bill H
The crank is just setting there I will turn it over before putting the cases together.
Bill H
